laser cross hair for plasma table
_Ogre
Post by _Ogre »
Laser X hair bracket.dxf
i posted this in my table thread but thought it ought to go here too
i made a cheapass laser cross hairs for the plasma table.
everything mounts on the torch head of the hypertherm powermax 65
cut this
folded it like this
and mounted it like this, the tabs are threaded 1/4-20 and welded in
i used 2 cheap 5V 650num Red line adjustable focal length laser that i found on ebay. $7 for 2 shipped from china
for power i used an old pc power supply that i had laying around.
yellow wires are 12v, orange wires 3v and red wires are 5 volt; easy peasy :D
the power supply needed a draw on it to work correctly, i add the 12v bulb just for the load
it's just wire tied to the center support under the table
i control the on/off with the xbox controller shoulder buttons.
preset functions for mist and flood coolant turn on aux outputs 2 & 3 on the candcnc box.
a little tweeking of the bracket with a die grinder gives me a true right angle locator for material
61 Sunliner
Re: laser cross hair for plasma table
Post by 61 Sunliner »
Very nice, it's amazing how help full laser cross hairs are.
Mike
HammerDownJustin
Post by HammerDownJustin »
Thank you sir..fixing to download and try it out when i build my next table.
Miller 251 Mig
Capstone
Post by Capstone »
very nice upgrade. This works with all Hypertherm machine torches?
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
s1lisboa
Post by s1lisboa »
Nice!!!!!!!!!!!
i_r_machinist
Post by i_r_machinist »
Excellent! Thanks!
i_r_
Zippo
Post by Zippo »
Thanks for posting.
1MORECUT
Post by 1MORECUT »
Nice Job :D
John
_Ogre
Post by _Ogre »
41 downloads and only 7 comments? come on guys, wtf??? :mrgreen:
these are the lasers from ebay, of course the price went up a few $
http://www.ebay.com/itm/131000895058?ss ... 1439.l2649
i ordered a lot of 10 as back up lasers for $3.50 each, shipped.
_Ogre
Post by _Ogre »
Capstone wrote:very nice upgrade. This works with all Hypertherm machine torches?
powermax 65 and 85 machine torch is all i know for sure
it even has the keyway for the gear drive that nobody uses :mrgreen:
of course you could always modify the hole for your torch
Robert
Post by Robert »
looks good thanks
mayper
Post by mayper »
thanks for sharing
Here is a laser cross hair I made for my table I have a Hypertherm 65 Machine torch on my DIY table.
These are HF lasers about $5. each no wiring needed, worked for finding the edge of the metal too.
Single screw holds it on easy to install and remove.
abmetal
Post by abmetal »
Acourtjester,
I really like your design. Might I enquire as to where you purchased your lasers? I like those better than the ones I have.
Allen
http://www.harborfreight.com/laser-marker-93242.html
Here you are I just removed the magnetic base and used the pivot screw to mount it to the aluminum ring.
_Ogre
Post by _Ogre »
that looks easy enough to make. from harbor fright site "Requires three 1.5 volt button cell batteries (included)."
3 buttons stacked make 4.5 volts. if you have to change batteries often convert them to the pc power supply. :mrgreen:
Robert
Post by Robert »
Thanks for sharing looks good.
Capstone
Post by Capstone »
Ogre, Thanks for sharing your design. I'm always impressed when someone draws 2d for something that finishes up in 3d and especially when it's a tool that makes things simpler or more precise, which your idea does both.
That said.. I gotta hand it to Jester. It's a super clean setup. I don't have a milling machine though, so I may have to come up with something in between.
Phil
CNC Metal Design
JD Squared 4x8
dikko
Post by dikko »
thanks for this share i really appreciate the work you all do on here well done this has fixed a real bug bear i have when aligning my table thanks again cheers from dikko
Here is a DFX file for the holder with the offsets for the mounting bracket of the HF laser.
ID is 1-3/8" for hypertherm PM65 machine torch and Trafimet machine torch.
Have fun
Tom
SlapNutz Fabrication
Post by SlapNutz Fabrication »
Brilliant designs guys, thanks for sharing.
superoverenginered
Post by superoverenginered »
Excellent design I guess i will finally be using my mill/drill machine for something other than drilling thank you!
Why make one when you can make 2
5x10 Arclight Dynamics plasma table
powermax 65
Concrete Printer with dewalt router
Miller mig/tig
HammerDownJustin
acourtjester wrote:Here is a DFX file for the holder with the offsets for the mounting bracket of the HF laser.
Have fun
Tom
Thank you for the file. Picked up 4 of them lasers at my local HF earlier. 50 mile drive so didnt want to chance one being bad. ;) ..Was fixing to measure the offset so I could draw one up and try to cut it from some 3/8" aluminum I have. Then seen where you posted up.
Miller 251 Mig
Zeke
Post by Zeke »
Thanks for the files and info
Zeke
_Ogre
Post by _Ogre »
had to search for this thread to post in another forum
buy a 10 pack of those ebay lasers, we've had to change out 3 of them in a year
