laser cross hair for plasma table
- _Ogre
i made a cheapass laser cross hairs for the plasma table.
everything mounts on the torch head of the hypertherm powermax 65
cut this
folded it like this
and mounted it like this, the tabs are threaded 1/4-20 and welded in
i used 2 cheap 5V 650num Red line adjustable focal length laser that i found on ebay. $7 for 2 shipped from china
for power i used an old pc power supply that i had laying around.
yellow wires are 12v, orange wires 3v and red wires are 5 volt; easy peasy
the power supply needed a draw on it to work correctly, i add the 12v bulb just for the load
it's just wire tied to the center support under the table
i control the on/off with the xbox controller shoulder buttons.
preset functions for mist and flood coolant turn on aux outputs 2 & 3 on the candcnc box.
a little tweeking of the bracket with a die grinder gives me a true right angle locator for material
an ogre smiley how cool!
Re: laser cross hair for plasma table
Very nice, it's amazing how help full laser cross hairs are.
Mike
Mike
- HammerDownJustin
Thank you sir..fixing to download and try it out when i build my next table.
Miller 251 Mig
Miller 251 Mig
- Capstone
very nice upgrade. This works with all Hypertherm machine torches?
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Nice!!!!!!!!!!!
Excellent! Thanks!
i_r_
i_r_
- Zippo
Thanks for posting.
- 1MORECUT
Nice Job
John
John
- _Ogre
41 downloads and only 7 comments? come on guys, wtf???
these are the lasers from ebay, of course the price went up a few $
http://www.ebay.com/itm/131000895058?ss ... 1439.l2649
i ordered a lot of 10 as back up lasers for $3.50 each, shipped.
- _Ogre
powermax 65 and 85 machine torch is all i know for sureCapstone wrote:very nice upgrade. This works with all Hypertherm machine torches?
it even has the keyway for the gear drive that nobody uses
of course you could always modify the hole for your torch
looks good thanks
thanks for sharing
Here is a laser cross hair I made for my table I have a Hypertherm 65 Machine torch on my DIY table.
These are HF lasers about $5. each no wiring needed, worked for finding the edge of the metal too.
Single screw holds it on easy to install and remove.
Acourtjester,
I really like your design. Might I enquire as to where you purchased your lasers? I like those better than the ones I have.
Allen
Allen
http://www.harborfreight.com/laser-marker-93242.html
Here you are I just removed the magnetic base and used the pivot screw to mount it to the aluminum ring.
- _Ogre
that looks easy enough to make. from harbor fright site "Requires three 1.5 volt button cell batteries (included)."
3 buttons stacked make 4.5 volts. if you have to change batteries often convert them to the pc power supply.
Thanks for sharing looks good.
- Capstone
Ogre, Thanks for sharing your design. I'm always impressed when someone draws 2d for something that finishes up in 3d and especially when it's a tool that makes things simpler or more precise, which your idea does both.
That said.. I gotta hand it to Jester. It's a super clean setup. I don't have a milling machine though, so I may have to come up with something in between.
Phil
CNC Metal Design
JD Squared 4x8
CNC Metal Design
JD Squared 4x8
thanks for this share i really appreciate the work you all do on here well done this has fixed a real bug bear i have when aligning my table thanks again cheers from dikko
Here is a DFX file for the holder with the offsets for the mounting bracket of the HF laser.
ID is 1-3/8" for hypertherm PM65 machine torch and Trafimet machine torch.
Have fun
Tom
Have fun
Tom
Brilliant designs guys, thanks for sharing.
- superoverenginered
Excellent design I guess i will finally be using my mill/drill machine for something other than drilling thank you!
Why make one when you can make 2
5x10 Arclight Dynamics plasma table
powermax 65
Concrete Printer with dewalt router
Miller mig/tig
powermax 65
Miller mig/tig
- HammerDownJustin
acourtjester wrote:Here is a DFX file for the holder with the offsets for the mounting bracket of the HF laser.
Have fun
Tom
Thank you for the file. Picked up 4 of them lasers at my local HF earlier. 50 mile drive so didnt want to chance one being bad. ..Was fixing to measure the offset so I could draw one up and try to cut it from some 3/8" aluminum I have. Then seen where you posted up.
Miller 251 Mig
Miller 251 Mig
Thanks for the files and info
Zeke
Zeke
- _Ogre
had to search for this thread to post in another forum
buy a 10 pack of those ebay lasers, we've had to change out 3 of them in a year
