Wildlife Scenery Firepit
Here is a firepit that some first-year welding students built. Pretty good projects for beginning welders. Can't really screw them up too bad!! Anyways, a thanks goes out to thissideup for the design of the firepit, and SignTorch and Jason @ freedxf.com for the deer, duck, bear, and turkey scenes.
In the .dxf file, there is a five-sided piece that we cut out to serve as a bending guide for the sides (angle was 145 degrees between sides and feet). The notch should be towards the top side. There are bootrail supports included that should match up to the angle of the sides, as well.
**may want to cut and build the sides of pit before cutting out the bottom to insure proper fit. After bending with rosebud, our bottom didn't fit quite as snuggly as intended.
Re: Wildlife Scenery Firepit
That looks awesome!
check us out ! www.thefirepitfactory.com www.polartracks.com
- Zippo
Thanks for posting.
- HammerDownJustin
Looks good and guessing you got the table back up..holler at me before that student cuts that bender please.
Miller 251 Mig
Miller 251 Mig
- Metal Storm
thanks for the share. this one is just the size I was looking for. I want to build one of the big monsters but do not have the shop space yet. still getting organized.
Metal Storm
by J.P. Janeway
nuke1jj@gmail.com
Plasma Cam DHC2
Thermal Dynamics Cutmaster 38
by J.P. Janeway
nuke1jj@gmail.com
Plasma Cam DHC2
Hi guys new at this. Awesome pit. What thickness are you using to cut this out of (1/8 in plate)?
That pit is 3/16". 1/8" would probably work fine for a fire pit, however. I am tempted to build a few and see how they withstand the heat. Definitely would be a little cheaper.bnechak wrote:Hi guys new at this. Awesome pit. What thickness are you using to cut this out of (1/8 in plate)?
Did you just heat and bend the bottoms or use a break?Scheub wrote:That pit is 3/16". 1/8" would probably work fine for a fire pit, however. I am tempted to build a few and see how they withstand the heat. Definitely would be a little cheaper.bnechak wrote:Hi guys new at this. Awesome pit. What thickness are you using to cut this out of (1/8 in plate)?
cdbradbury wrote:Did you just heat and bend the bottoms or use a break?Scheub wrote:That pit is 3/16". 1/8" would probably work fine for a fire pit, however. I am tempted to build a few and see how they withstand the heat. Definitely would be a little cheaper.bnechak wrote:Hi guys new at this. Awesome pit. What thickness are you using to cut this out of (1/8 in plate)?
We heated them with a rosebud torch. Wasn't too bad, but a brake would be a lot faster for sure. In the file, I drew a little angle gauge that we cut out and used to be sure it is bent to the correct angle, which worked pretty well. The half circle cut-out on the top of the angle gauge goes towards the top.
Alright, Someone help me to know where the boot rail straps are positioned. Thanks in advance
There is really no set position for the boot rail straps, other than we welded them flush to the top of the sides. I want to say we put them about 2" in from the corners, as well.Barnett_9437 wrote:Alright, Someone help me to know where the boot rail straps are positioned. Thanks in advance
Thanks for the reply. That helps
Thanks for the design!
- CNCCAJUN
Thank you . . . very nice . . .
OK, I admit I am puzzle challenged . . .
Where do the (8) little pieces go?
I'm thinking somehow they support the bottom.
I looked at the picture and I am stumped. . .
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
CNCCAJUN wrote:Thank you . . . very nice . . .
The 8 small pieces are supports for a boot rail... Just realized that I didn't include any pictures with the boot rail so I understand the confusion. We place them flush to top of the pit (2 per side), longer side facing down, and the add some thin-walled square tubing as a boot rail. The random 5-sided piece is used as a bend guide when bending the sides; just heat and bend to match the angle.
That's awesome! Thanks! What type and thickness of metal do you recommend?
I use 3/16" thick mild steel. 3/16" seems to be thick enough to not warp or rust through too bad, but light enough to not make the pit too terribly heavy. The wildlife pit was designed to be able to fit two pits on one 4' x 8' sheet.prophetproducts wrote:That's awesome! Thanks! What type and thickness of metal do you recommend?
Well Done!
i love this pit design and how customizable it is. one quick question though, if i scale up the base plate to 18"x18" will everything line up correctly?
This is awesome........wish I would have seen this before we DUG a firepit.....now we have to redo to make sure grandkids don't fall in.
Great job.!!!
Toni
Great job.!!!
Toni
Great file, thanks for the share.
Pat
Pat
I keep getting line 10 code error, please help. Great pc. ,would look good where my wife's bird bath was. THANKS
Very nice cant wait to cut this out
Thank you very much for the file! We are dirt track racers so modified it just a bit to show our car number.. turned out really nice!
Here's mine. A hunting theme.
Homemade 36X36 table
Can go from Plasma to Router in 10 Minutes
American Modified Chinese Controller
Proma Electronics THC
Cambam and Mach3
Longevity Forcecut 40D
Miller 211 MIG Welder
Cambam and Mach3
