Garden Sundial DXF FIle
Re: Garden Sundial
extremely nice work carn't wait to cut and build one of these up.
Re: Garden Sundial
That link that muzza provided tells what angle to make the gnomon and where to position the numbers, but how do you know how long to make the gnomon? I think I will build one of these.
- SCHIDTHEAD
Re: Garden Sundial
The gnomon is in the cut file; no need to make it.Metriccar wrote:That link that muzza provided tells what angle to make the gnomon and where to position the numbers, but how do you know how long to make the gnomon? I think I will build one of these.
"Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one."--Thomas Paine 1776
Re: Garden Sundial
That is beautiful. Thanks.
Re: Garden Sundial
Really nice file
thanks for sharing it.
This will look outstanding in my back yard
Re: Garden Sundial DXF FIle
That is beautiful!
I really want to make one of these, but sort of confused by this statement:
***ALSO--this dial is set at 38.85? N as with the gnomon, so if you want it to keep accurate time for your location, the dial angles and the gnomon have to be set to your latitude.
How do I go about doing this? Like let's say I want it to be 31? N.
- SCHIDTHEAD
Yes, your angles of the dial numbers, relative to 180 degrees, and the angle of the gnomon / are set to your latitude.Metriccar wrote:I really want to make one of these, but sort of confused by this statement:
Go to: http://www.anycalculator.com/horizontalsundial.htm and enter your latitude in the calculator and it will give you your angles for the hours, and, depending on where you live, deflection of true north as well.
As for the gnomon, if your latitude is 31* N, your gnomon's angle will be 31* to be perpendicular to the earth's axis.
Hopefully this helps, if not p.m me and I can set up your correct sundial to your zip code and really get your dial dialed in.
Steevo
seem that I am having trouble fixing this file. When I down load the file all the line are broken. Ive tryed to fix the file with Corel x5 but my computer keeps jamming. Is there some other DFX file out there that some would like to share
Patrick
- SCHIDTHEAD
when I find time I will load it into X6 and see what it does...I dont use CorelDraw for my dxf designing, more for graphic art; my dxf designs are all done in CAD
Thanks for sharing, that is sweet
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
- SCHIDTHEAD
Yaller very wecome...
- 4.5 Star Member
Schidthead,
I can't believe my luck.
I did a sign for a friend of mine for his house. He said he's also interested in a sundial. Well that left me scratching my head a bit.
I haven't looked at this section of the forum for about 3 weeks and what's the first thing I see when I decide to look again.
Awesome, thanks for your great generosity in sharing such a wonderful piece.
Keith.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
very nice work, I am new to the forum congratulate greetings
Wow, This is amazing. I am new to this site and really appreciate your work and generosity in supplying the dxf file of the sundial. My wife loves the look of it and this will be my first big project on my plasmacam. Thanks again.
Richard
Richard
awesome, Thanks
Man what a beautiful piece of work. THANKS !!!
Thank you
WOW! NICE!
super job
thanks for the file.
i found a site that has software that you can download and set your location and create all sort's of
sundials. (free) that's always nice.its called shadows.
here it is,i hope this helps someone.
http://www.shadowspro.com/en/index.html
Thank you for this file!!
Awesome piece Thanks
- rdj357
Beautiful work, thanks for sharing!!
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
