Plasma cut for my new downdraft Watertable Part 1
- East German
Hallo,
my new Homebuild Plasma.
-working surface 1030 mm x 1550 mm
-two fans
Works very well no smoke in the garage!
Regards Peter
-two fans
Regards Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
- East German
Re: Plasma cut for my new downdraft Watertable Part 1
Part 2
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
- East German
Part 3
Exhaust is not finished
Regards Peter
Regards Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Looks like a great design.
- tnbndr
Very nice job.
And look at that stacked house of firewood! It would take me a lifetime to get firewood to stack so neatly.
- East German
tnbndr wrote:Very nice job.
Hallo Denis
If only outside a row of wood.
In the middle are Tractor and co
Regards Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
- tnbndr
Ahhhhhhhhhhhhh, very tricky!!!Hallo Denis
I have a question...did you build tanks for the military? lol
Nice job, heavy duty is good. how does the downdraft work?
i went through many ideas to downdraft my custom built table
and just couldnt get the power i was expecting for my home garage
so i went back to a revised water pan ( all aluminum except cross grade slats)
- East German
Hallo,x5er30 wrote:I have a question...did you build tanks for the military? lol
heavy duty is good, my old Watertable was 3 mm it s in the Time very bending.
The new Table is 5,5 mm Steel with 5 % Nickel, this steel is fore gas barrel!
The two fan makes about 1000cfm its very fine!
I think this is the correct construction,it is very much better than before with the old Watertable.
I am absolutely thrilled after a few days.
Regards Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
VERY well done Peter!!!!!!!!!!!!!! Wish I had your patience and insite
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
- pertneer
Nice work. Should hold up very well over time. I see your table slats are a unique design. Do they slide along the length of the slats to the location you need for what you are cutting? Does slag build up to inhibit their movement?
- East German
pertneer wrote:Nice work. Should hold up very well over time. I see your table slats are a unique design. Do they slide along the length of the slats to the location you need for what you are cutting? Does slag build up to inhibit their movement?
Hallo,
they slide along the length is 12 mm Steel.
The slag is removed with a hammer is very stable.
Regards Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
