Incomplete cuts
Re: Incomplete cuts
I did think about that control THC setting I assumed it was to permanently have the THC switched on regardless on the thc on switch on the run screen. In my case I want the THC off but UCCNC respect the arc ok light.
Home built 4x4 Plasma Cutter
UCCNC
Oxford 350 Plasma Cutter with machine port.
Trafimet Autocut S65P machine torch
co2 1200x600 75 watt laser
Co2 1300x900 100 watt laser
UCCNC
Re: Incomplete cuts
Finally got it cut, been busy with my normal part of my business
Mick
Owner/ operator
MJT rural Contracting
Weldclass t1200
Hypertherm Pwermax 45XP
Owner/ operator
Weldclass t1200
Re: Incomplete cuts
Nice job Mick! Since you don't have Design Edge to use for linking, you could also buy a copy of LightBurn for $60. You can get a 30 free trial to try it out. If you import your dxf into LightBurn and then export as dxf, it will automatically link your file the same way Design Edge does.
https://lightburnsoftware.com/pages/tri ... re-you-buy
Re: Incomplete cuts
Thanks David I'll have a look at it
Mick
Owner/ operator
Weldclass t1200
Owner/ operator
Weldclass t1200
