DIY toolboard
Mtw fdu
Re: DIY toolboard
Post by Mtw fdu »
Jason@bc wrote: Sun Mar 19, 2023 3:36 pm Nice work Mtw fdu, a (well thought out and organized storage/work-station) can save a ton of time, my only problem sometimes is keeping it that way...LOL.
Thanks for your comments Jason@bc. Another project that is almost completed. Then onto the next 1.
Mtw fdu.
Camcutcnc 4 x 4 plasma cutter with UC 100 Motion Controller
Powermax 45 with Machine Torch
Bobcad V27 and Mach 3
Proma THC
Now with Rotary Axis
Laser cross hairs
toasterman12
Re: DIY toolboard
Post by toasterman12 »
Jason@bc wrote: Tue Dec 20, 2022 10:12 am I like the cement mixer idea, might be the least expensive way to go, thanks Jester.
no freakin way, just so happens I have a mixer that was left behind when I bought the house, thanks for the pro tip.
would sand benefit as a medium for descaling or not worth the effort?
Re: DIY toolboard
toasterman12 wrote: Fri May 19, 2023 4:50 am
Welcome aboard Toasterman12! You could try sand to see if it makes a difference (or not). I used to tumble my brass using cobmeal grit mixed with Brasso. It worked great. I haven't personally tried the cement mixer approach on plasma cut parts. If you try it , be sure to let us know how it works for you.
Jason@bc
Re: DIY toolboard
Post by Jason@bc »
It can't hurt to try sand, I know some guys who don't put any media in...just steel on steel.
robertspark
Re: DIY toolboard
Post by robertspark »
sand may be a little soft and just turn to dust.... it may work but it may take a hell of a long time
try a hard "sand" garnet.... used for sand blasting (I have used a 40/60 mix for sand blasting with a pressure pot and have reused it many many times)
https://www.kuhmichel.com/uk/products/garnet-sand/
there are some other materials listed here:
I have used glass beads for aluminium (works well), and aluminium oxide (cuts a little too quick for me, not for aluminium!), that is with sand blasting not a tumbler.....
don't use "sand" {river / play sand} for sand blasting as it has a high silica content and because it turns to dust very quickly you are likely to end up with lung problems (unless of course you use REALLY good respiration). https://www.osha.gov/sites/default/file ... HA3697.pdf
