TATTERED AMERICAN FLAG
Re: TATTERED AMERICAN FLAG
is there a recommended thickness for the steel ?
I use 16 gauge for small ones.
TruCut 5x10
Victor Plasma
Thermal Dynamics
Sheet Cam
Rhino3d
Bobcad
Victor Plasma
Thermal Dynamics
Sheet Cam
Rhino3d
Bobcad
THANKS NEED THESE IN EVERY SCHOOL
I downloaded the DXF for this, however, all the lettering came into sheet cam with two start points per letter. Anybody else run into this? and what was the fix??
Thank you so much! Great detail!! Thanks for sharing
Hi, I am new to this forum and I love it! Does anyone here happen to have any Canadian Flags, Uk Flags etc??
Would anyone happen to have this file with the 2nd amendment on it.
Here is a version I cleaned up a bit, Haven't cut it out yet though.
Just as a heads up, those sharp points can injure someone (yeah, ask me how I know) anyways I rounded all the flag points. But this is the most awesome flag when all done!!
Awesome ,Thanks
Thanks for the share. here it is cut out.
very cool. thank you
heres one ive cut
Thank you!
All American Share. Thanks
Thanks for the share!
Okay, I am using a Viper Cut 30 amp plasma cutter with a .8 nozzle 90psi cutting at 100 ipm. Will this file work to cut with what I have, or is it more meant for a laser cutter?
Shawn P Boller
S and L Weld Services, LLC
Yes this will work with what you have, most if not all these guys are cutting this with plasma.
I got this from here proballz03
I am having a problem doing the cut lines on the flag, it only wants to do small lines when o go to click on a cut line. How can I fix this?
- ETCWeld
thanks for the files and thank you for the videorickjamesbish wrote: ↑Wed Jan 18, 2017 9:42 am If this video works https://youtu.be/97sKopToMCE you can see as I remove masking how I do mine. Disposable vinyl sounds like a plan.. depending on cost.
Very nice flag thanks for the share
when ever i run this program it stops cutting around step 2460ish some help would be greatly appreciated
Are you guys welding brackets on the back of the flags? Or how do you tell your customers to mount them?
