Hi,
I want to try cleaning my cutouts using muratic acid but I am not sure what type of mask to wear against the fumes.
Would a standard type pint spraying mask or is it something special?
Thanks.
Tony
What type of mask to use with acid?
- tony506
Eastern Canada
Hobby Shop/Business
PlasmaCam DHC2 with Design Edge
Hypertherm Powermax 65
Lincoln Mig
Everlast Tig & Stick
Hobby Shop/Business
Lincoln Mig
Re: What type of mask to use with acid?
its something special. the fumes are really bad . you probably want to dilute the acid a bit .
home depot and lowes have a mask it says on the package for muratic acid its pretty hefty
I think its like 40-50 bucks
trust me you need it.
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
When I use muriatic acid, I'm either outside where there's a breeze or when I'm inside I use a fan to keep the fumes away from me. The bad thing about being inside is that the fumes are going to rust any steel they come in contact with.
Allen
Allen
- tnbndr
I have switched to vinegar. It takes a little longer but no worries about fumes or rusting every piece of metal in the garage and house.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
You need to use a mask and filters that cover organic vapors. links below are what I use. It covers the acid, other gases, paints, solvents, etc as well as particulates, dust, smoke etc.
http://www.northernsafety.com/Product/6 ... ges-2-Pack
http://www.northernsafety.com/Product/6 ... Respirator
(If the links don't work, just copy the addresses into a web search)
- tony506
Thanks fr all the help.
I plan to use it outside, but want to use a mask to be extra care. I have ordered one from Northern Tool.
I am going to try the vinegar as well, I never knew that.
Thanks to all
Tony
Thanks to all
Tony
Eastern Canada
Hobby Shop/Business
Lincoln Mig
Hobby Shop/Business
Lincoln Mig
