Corner welding clamps
cbassjr
Post by cbassjr »
I know most of you may already have made your own but I designed a set of heavy duty welding corner clamps. If interested I'll post the dxf. They will go up to 6" square tubing or around 4" pipe. Let me know if you want the dxf. This size clamp retails on the net for around $400 each. Requires a little welding and some angle iron, all thread and a couple of nuts but they work great for doors and gates. They have saved us hours in fan time.
abmagrum
Re: Corner welding clamps
Post by abmagrum »
I could use it . and I am sure others could use it.
thanks in advance
Al
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
GWS.Arkansas
Post by GWS.Arkansas »
yes I also would love the file. Thanks in advance.
cbassjr
Post by cbassjr »
Looks like there's interest I'll try to post Sat or Sun as I'm headed to a trade show and my notebook is packed. If I have internet access at the show I'll post be then. Thanks for then interest. It is pretty straight forward to cut the angle iron and weld up. If after you download anyone with questions is welcome to ask for instructions. The biggest thing is after you weld and grind down the base I used that to square up the clamping base to square up and weld on the upper clamp angle iron I can't remember if the slot is 1/2" or 5/8" I think it's 1/2" you need to be sure the slot bolt it in before you weld up the smaller angle iron. The back brace where the t-handle has the weld on nut and the clamping end has a nut on one side of the plate and one on the other side so it turns freely. I hope this will help everyone.
bigcreek
Post by bigcreek »
Definately interested! Thank you
Capstone
Post by Capstone »
Thanks for sharing!
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
cbassjr
Post by cbassjr »
Here is the dxf for the corner angle clamps. Sorry for the delay.
angleclamp.dxf
(50.24 KiB) Downloaded 153 times
bigcreek
Post by bigcreek »
Thank you Cbassjr for that file! Much appreciated.
