Making Tools/Machines with Plasma Cut Parts
I am curious to see if anybody is using their tables to make parts that work together to create tools or machines. Let's see what you have.
Re: Making Tools/Machines with Plasma Cut Parts
heres a couple of things. the forge i made because i'm cheap and the ring roller it made because i needed to be 6" wide
- Metal Lee
Is that a burner from zoeller forge?
Thanks, Metal Lee
yes it is. but you can go to the hardware store and get everything you need with the exception of the stainless tip thats inside the forge.
- Metal Lee
Did you make your own SS burner Flare ?
Thanks, Metal Lee
- Scratch
Nice forge! I guess I've also used my CNC table to make tools like a forge....
Here is the day the paint was dry on it. Took it inside to...... not sure why I took it inside.....?
Here is after a couple weeks and decided to add some color to it.
- Scratch
Dang it.... forgot about the resizing thing again!
- Loyd
The reason I bought my PlasmaCam was to bring the capability to do more of my product in-house. We cut several of the parts on our reels with the Pcam.
Loyd
Loyd
- Attachments
- oa37b.gif (13.33 KiB) Viewed 3634 times
