6 sided fire pit, dxf and pcm
here it is, enjoy and please post your versions.
check us out ! www.thefirepitfactory.com www.polartracks.com
Re: 6 sided fire pit, dxf and pcm
Nifty, thanks for the share!
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
You are too generous !!! Thank you soo much. I made one of your other fire pits and it turned out so nice. I can't wait to cut one of these.
How big is this pit fire box? How much of a 4x8 sheet does it take?
Thanks for the share, looks good.
Murray
Murray
Nice, what angle is the bend?
google sketch up says it's 124.8 but i just bend by eye so i can't confirm.wickedinhere wrote:Nice, what angle is the bend?
- MetalheadRK
Very nice! Thanks for sharing.
4x4 PlasmaCam
Hypertherm 45
Eastwood 175 MIG welder
Hypertherm 45
How big across is this one?
36 across the points, 32 across the flatsstarr_motorsports wrote:How big across is this one?
Sweet, thanks!
I like it, but for the numbers, you spend more time welding on this one. Though you might have a higher premium with 6 customizable sides.
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
- TEXRAMSEY
I like the fire pit. Will be trying it soon. Thanks
- yeomansjon
Looks great! I like the lettering, what font did you use?
Fast Jonny Custom Design
CNC Plasma Cutting
Plasmacam DHC
www.facebook.com/fastjonnycustomdesign
CNC Plasma Cutting
Plasmacam DHC
- CNCCAJUN
Would that also be a 55.2 degree bend?thissideup wrote:google sketch up says it's 124.8 but i just bend by eye so i can't confirm.wickedinhere wrote:Nice, what angle is the bend?
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Here are a couple some students made. Made a slightly smaller version also. Great file thanks for sharing. Is $100 for blasting and ceramic coating reasonable?
Does the ceramic coating hold up better to the heat? I was going to use flat black high temp spray paint?
honestly I have no idea, I just scroll through the fonts till i find one I like.yeomansjon wrote:Looks great! I like the lettering, what font did you use?
absolutely, I wont start my sand blaster for less than $100.No Class wrote:Here are a couple some students made. Made a slightly smaller version also. Great file thanks for sharing. Is $100 for blasting and ceramic coating reasonable?
- tnbndr
$100 for blasting and ceramic coating is almost like free.!!
Do it and let us know how the ceramic holds up to the heat. They use it on engines and exhaust systems so I would assume it will be fine.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Is this file missing the base at the bottom?
Thanks for sharing going to give it a shot.
Andy
Andy
Hi, thanks for sharing the 6 sided fire pit. It is awesome. I just cut it out tonight, but I am having a hard time getting the sides to match together nice. Does anyone know what the bend is on this firepit? I will post a picture once I get it all together. It is customized on the top side and the bottom. Turned out really nice, if I can just get the right angle for the bend. Thanks for any help that anyone can give me.
Just completed a fire pit with this dxf, some customization was done with words around the base. I set the protractor to be 125 degrees around the outside radius of bends, worked out perfectly!!! Thanks a lot!!! It is more welding but it could also be made from left over scraps from other projects, so that is a bonus!!
Countrylane Metal Art Work
