3d snail
- david jordan
Re: 3d snail
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
- Cz_apie
Re: 3d snail
Plasmacam 4x4 DHC2 Table
Design Edge 4.36 Advanced Design
Advanced Height Control
Hypertherm PM 65
Mac Afric Cut 40 Plasma
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
13" Metal Lathe-Milling Machine
Rong Fu 25 Mill
Hypertherm PM 65
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
Rong Fu 25 Mill
Re: 3d snail
I really like this, and would like to cut it out. Downloaded it a couple of times, but get an error in Inkscape (Inkscape has received additional data from the script executed. The script did not return an error, but this may indicate the results will not be as expected.)(Traceback (most recent call last):
File "dxf_input.py", line 530, in <module>
inkex.errormsg(_('%d ENTITIES of type POLYLINE encountered and ignored. Please try to convert to Release 13 format using QCad.') % polylines)
NameError: name '_' is not defined
Anyone might know why this is happening?
Re: 3d snail
Opens fine in Corel, try this svg in Inkscape you may have better luck. The file contains the cutpaths also so you may need to delete some objects.
Re: 3d snail
Thanks for the snail, very cool and inventive. Cant wait to cut it.
Thanks for sharing
Thanks for sharing
