I have tried printing a few projects using Inkscape with no luck,
Have used Autocad in the past for templates, print them tape them down presto.
Yesterday I down sized a traced photo to a desired size for a wooden template spent hours and could not print it.
I tried saving it DXF into autocad and It did not show up so that didn't work, as well as snipping it, that threw out the scale I was after, Tried everything I could think of but putting the pen one my machine to do it. Any suggestions?
Printing a 1:1 Trace Using Inkscape ?
- steel 35
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Re: Printing a 1:1 Trace Using Inkscape ?
Ok with Inkscape you need to set the scale before you start drawing, Go to file menu down to "Document properties" click on it. I un-click Show page borders and then in the upper right under "default units" arrow click on "in" for inches. Then you will have the correct scale you can print thing less then 8"X 11" I don't know how larger part will show up on paper. It may print many pages that you can overlap and tape together???
- steel 35
I Just learned from watching part of the the short videos you posted how to change to Inches what a pleasure that was.
I made a quick test round corner box 3"X 4" came out solid black the hole page! No fill selected, simple outline box. No can do.
I got my project done by making a template out of 14G but not what I was after
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
rut row something not right one ink cartridge down the drain
I could understand the box being full not the whole page
- WyoGreen
It seems like I've had this happen to me. If I remember right I had an older printer, and the driver was the problem. My new printer has no problem at all with it.
At least that's how I remember it, Steve
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
