Another try at putting clipart together. Thanks for all the inspiration you guy's and Gals give on this site. Would appreciate any input, advice, comments or constructive Criticism that will help me get better at this. Thanks again
Wild Mustang
Wild Mustang
Re: Wild Mustang
The art work is very good
IMHO there are some thin places that not supply enough support and could bend easy.
Re: Wild Mustang
Nice job, looks great!
Cincinnati CL-940 4000 watt Fiberoptic Laser 5' x 10' Dual Pallet
Re: Wild Mustang
I like it. thanks for sharing
Re: Wild Mustang
You have asked for input so I have downloaded and had a quick look at it. Great work but there are a couple of areas that need a bit of attention. The area's I have filled blue are contained in an area which will be cut away (the grey area) so will be lost and there is an overlapping line in the area colored red. Also as has already been said some areas may not have a lot of meat but as a static piece you should get away with them.
Good to see people having a go, keep it up and thanks for sharing your journey.
Murray
Murray
Re: Wild Mustang
Thanks muzza for the input, I see the area that will fall out as you stated. I need to give a lot more attention to those areas. I really appreciate everyone's input.
muzza wrote:You have asked for input so I have downloaded and had a quick look at it. Great work but there are a couple of areas that need a bit of attention. The area's I have filled blue are contained in an area which will be cut away (the grey area) so will be lost and there is an overlapping line in the area colored red. Also as has already been said some areas may not have a lot of meat but as a static piece you should get away with them.
Murray
- hdfaster
Re: Wild Mustang
Nice looking file, thanks for sharing it. And Thanks muzza for the heads up on the details.
Re: Wild Mustang
thank for sharing
Re: Wild Mustang
thanks that is a nice looking horse
