Hello all, I've discovered a new problem (actually it's not new, it was never that important before this point).
For some reason when I'm cutting an item that has multiple start points (like most projects) my Mach 3 slows down after the second cut, i.e., for a specific item I'm cutting now, my speed is 60ipm, after the second pierce I'm dropping to 20ipm, I'm assuming it is something sheetcam is producing in the Gcode, anyone else have these types of issues? It doesn't always do it, that's the weird part.
Cut speed decreases after second pierce.
Still learning!
4x8 homebuilt w/Water table - Hypertherm Powermax 45 (Machine torch)
13" Metal Lathe
7x12 Meta lathe
1-1/2hp Milling machine
Hobart 190 Wire feed
Hobart EZ-Tig
Elcheapo powdercoating gun W/Autoclave oven converted for powdercoating.
13" Metal Lathe
7x12 Meta lathe
Hobart EZ-Tig
Re: Cut speed decreases after second pierce.
What version of SheetCam? What post processor are you using to create the G-code?
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Miller 350P
For the second cut is there any "cut rules" used that may have been accidently placed in the G-code.
Attaching a section of the G-code for the starting of the second cut may help to see.
Sorry Guys - Its been a busy week at work.
The version of SheetCam im using is 6.0.15 - honestly I know its silly, but I'm a little worried to update until I get all the bugs worked out.
Here is the Gcode from the end of the first cut.
N1310 M05
N1320 G00 Z0.5000
N1330 X3.8300 Y2.4855
N1340 Z0.2200
N1350 G90F100
N1360 G31 Z-3 F20
N1370 G92 z0
N1380 G0 z0.16
N1390 Z0.2200
N1400 M03
N1410 G04 P0.06
N1420 G01 Z0.1800
N1430 G02 X3.7500 Y2.4055 I-0.0800 J0.0000
N1310 M05
N1320 G00 Z0.5000
N1340 Z0.2200
N1350 G90F100
N1360 G31 Z-3 F20
N1370 G92 z0
N1380 G0 z0.16
N1390 Z0.2200
N1400 M03
N1410 G04 P0.06
N1420 G01 Z0.1800
Still learning!
13" Metal Lathe
7x12 Meta lathe
Hobart EZ-Tig
13" Metal Lathe
7x12 Meta lathe
Hobart EZ-Tig
That looks like a post processor issue to me. What post processor are you using?
Ill have to double check, I believe it is a Mach3 one that I had to modify . Is there a line of code that jumps out to you as being wrong?Les Newell wrote:That looks like a post processor issue to me. What post processor are you using?
Still learning!
13" Metal Lathe
7x12 Meta lathe
Hobart EZ-Tig
13" Metal Lathe
7x12 Meta lathe
Hobart EZ-Tig
line N1350 looks odd. I wouldn't have expected a G90 there.
- WyoGreen
I see a speed rate change to 20 in line 1360 (N1360 G31 Z-3 F20), but no feed changes after that.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
ok - I see the problem...
Looking at the initial Pierce;
N0110 G00 Z0.5000
N0120 X2.9116 Y1.3529
N0130 Z0.2200
N0140 G90F100
N0150 G31 Z-3 F20
N0160 G92 z0
N0170 G0 z0.16
N0180 Z0.2200
N0190 M03
N0200 G04 P0.06
N0210 G01 Z0.1800 F60.0 < - Feed rate is set in the Post processor from speed input in sheetcam
VS
The second Pierce
N1320 G00 Z0.5000
N1340 Z0.2200
N1350 G90F100
N1360 G31 Z-3 F20
N1370 G92 z0
N1380 G0 z0.16
N1390 Z0.2200
N1400 M03
N1410 G04 P0.06
N1420 G01 Z0.1800 < - Feed rate is not being transferred, its still running the speed set back on Line N1360?
I'm not sure what I'm missing in the Post Processor to get the same feed rate I achieve after the initial pierce.
function OnPenDown()
if (preheat > 0.001) then
post.ModalText (" G00")
post.ModalNumber (" Z", cutHeight * scale, "0.0000")
post.Text ("\n G04 P")
post.Number (preheat,"0.###")
post.Eol()
end
post.ModalText ("\n G90F100\n")
post.ModalText (" G31 Z-3 F20\n")
post.ModalText (" G92 z0\n")
post.ModalText (" G0 z0.16\n")
post.Text (" Z")
post.Number (pierceHeight * scale, "0.0000")
post.Text ("\n M03\n")
if (pierceDelay > 0.001) then
post.Text (" G04 P")
post.Number (pierceDelay,"0.###")
post.Eol()
end
end
Thoughts on a solution?
N0110 G00 Z0.5000
N0130 Z0.2200
N0140 G90F100
N0150 G31 Z-3 F20
N0160 G92 z0
N0170 G0 z0.16
N0180 Z0.2200
N0190 M03
N0200 G04 P0.06
VS
The second Pierce
N1320 G00 Z0.5000
N1340 Z0.2200
N1350 G90F100
N1360 G31 Z-3 F20
N1370 G92 z0
N1380 G0 z0.16
N1390 Z0.2200
N1400 M03
N1410 G04 P0.06
post.Eol()
end
post.Text (" Z")
post.Eol()
end
end
Still learning!
13" Metal Lathe
7x12 Meta lathe
Hobart EZ-Tig
13" Metal Lathe
7x12 Meta lathe
Hobart EZ-Tig
