color selection for different layers
Here is something I just found that helps with layering in Inkscape that helps for setting up contours for cutting in SheetCam.
high lighting an item and changing the color makes it a different layer, here is the way to keep all similar items to have the same color (layer).
After selecting the first item and assigning a color (layer) copy the color code from the stroke color box at the lower right. Then for all other items you want on the same layer, high light it and the paste the color code in the box. now in SheetCam all those items (layer) will be separate and be on different contours for cutting. :D
Capstone
Re: color selection for different layers
Post by Capstone »
good to know trick. thanks Jester
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
SeanP
Post by SeanP »
Well explained Tom how to use that feature, I sort of half looked at it not so long ago.
Is it not easier just to do it in sheetcam though? at least you get to give the layer a name that means something
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
I have used the SheetCam method many time, just a way to do it while you are drawing the project before saving it. Both work well.
AS you draw things you can use the paste to ID the layer yo want to use. In SheetCam I use the un-check method so each item goes away as I select them to be sure I get them all, then re-click to put them back in the image when done.
have fun
tom
SeanP
Post by SeanP »
Good stuff Tom, that's a good tip to unchecked each layer to be sure you got um all.
Powermax XP45
Table build gallery
Happy to help
Small payback for all the good stuff I have found here :)
Return to “Inkscape”
