Thought I would throw this out here. Did a search for one and found zero. Originally drew the JS one back in 06. just traced the other one from Jpeg.
I have downloaded many great files from here and look forward to contributing what I can.
Update. I have revised the heartogram file and I believe it should work now
Thank you
Heartagram Heartogram
Re: Heartagram Heartogram
In TM cad, to save image as jpg select the image, click on file, then "export image" , then select your resoulution and click ok, then you will be prompted as to where to save and name the file, and you can select type of file to save as there. Hope this helps.
Redneck wrote:In TM cad, to save image as jpg select the image, click on file, then "export image" , then select your resoulution and click ok, then you will be prompted as to where to save and name the file, and you can select type of file to save as there. Hope this helps.
Thank you. I figured it out last night.
crbattery wrote:Thought I would throw this out here. Did a search for one and found zero. Originally drew the JS one back in 06. just traced the other one from Jpeg.
Thank you
I have an issue with the files I am uploading. If I download it from this site and click on the little windows tab on the bottom left corner it opens in my cad program, however, when it opens every piece between nodes is a separate piece. If I import it from my files then it opens just fine and is still put together as I had uploaded it. Any ideas? I am running windows 10 with torchmate 8.. Thank you!!
Merry Christmas to all
- larrycameron44
Try to "select all", and "connect path" and it should join everything together.
NZ
NZ
larrycameron44 wrote:Try to "select all", and "connect path" and it should join everything together.
NZ
That does work. i would still like to figure out how to just get it to open the same way it does when I open it from the folder it downloads to.
