I have a customer that wants a Bumblebee 50x42 cut out of "thin" brass. The material is $1075 for a 4x10 sheet of 1/8 in. The supplier I checked with out of Houston said the 4x10 sheets start at 1/8 in and go up. The thinnest I could get in 3x8 sheet is 24g and it's $300. Those prices are for pick up only. I would have a 4 hour drive to pick it up. Do any of you have any experience cutting brass sheet? Due to the cost of material if I screw up I am considering outsourcing it to a local water jet company. Any thoughts or suggestions?
Cutting Brass Sheet
Cutting Brass Sheet
Stephen W. Sparks RN,CRN
Creating Sparks Metal Worx
Arclight Dynamics Arc Pro 12000 5X10
Linux, Sheetcam, Inkscape, Solid Edge
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
"Ridin around having a big time!"
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
Re: Cutting Brass Sheet
i like the waterjet idea. practice on the drop.
I had the same considerations for an estimate recently too. Customer wanted silhouettes cut out of copper. Best price I got was $600 for a 4x8 16GA sheet. I gave them the price of $900 for the sheet and told them I'd charge by the inch for the cuts and do them pretty cheaply. Luckily they said it was too much. I was worried that if I was doing big cut outs on it and the machine had an issue I'd have to eat a sheet of copper to finish the job. I wanted to try it but I was glad they decided against it.
Did you show him the finishes that he can get from Steel FX stains? My wife gets some pretty cool brass/copper finishes with that stuff.
i_r_
i_r_
- Gogogadget62
I tried cutting brass and it was not that great,,,,,,,,using water jet would be your best bet for the price of the material
Dan Gauthier
5x10 Samson
Miller 185 wire feeder
600 Hypertherm
45 Hypertherm
85 Hypertherm
40 ton press and dies
powder coating
80 gallon DeVAIR compressor 5Hp
5x10 Samson
600 Hypertherm
45 Hypertherm
85 Hypertherm
powder coating
Not sure where my previous reply landed...
I cut 16 gauge C464 brass with decent results. It is a bit expensive and my customer still decided on brass even after offering other look-alike options. I babysit the brass cuts at these prices.
