Here is something I have been doing for years and it has been very successful for me.
When I use paints and hardeners when I close a partially used can to be stored to be used later. I use Argon gas from my Tig setup to drive out the oxygen/air out of the container. This stops the paint from getting a skin on top and the hardener from hardening. I have a quick connect fitting in the line between the tank and Tig unit. The flow meter regulates the gas to a slow low pressure flow Argon is heavier so it pushes out the air before I attach the lid or cap on the container. It only takes about 15 seconds of flow to do the trick. This also works on PVC glue too.
Paint saver
Paint saver
- little blue choo
Re: Paint saver
Are you kidding me? I will have to try this. Thanks
Rick
Rick
Rick
Arclight 9600 4x8 table
Re: Paint saver
Me toolittle blue choo wrote:Are you kidding me? I will have to try this. Thanks
Rick
Thanks Tom
