Mach3 and one strange torch height problem
Ok so I got robbed when I bought this table as I got the last one delivered before Chris went dark. So far I had to make my own replacement head for the torch and fix a couple minor things.
Since cut one this thing has run high and slowly gotten higher. Now it starts, plunges, then as soon as it starts to cut will go to .785" every time. This is with the cut height changed in the tool on sheetcam to -.05".
What I've figured out so far. With the torch touching the steel it's all but at zero on the Z. Toss a piece of quarter on the steel and touch it, .250 or very close so it seems it knows it shit on that end. I turn the thc off in mach3 and start the cycle and it goes to, you guessed it, .785.
Any ideas on where to look next? I have another laptop coming in tomorrow that has another copy of mach3 on it that's never been plugged into the table to try.
Re: Mach3 and one strange torch height problem
With torch touching the steel how far out are you on the DRO? Is there a place to set the tool length in your setup and is it correct? Maybe your just .780" out on your tool length.
Zero or really close with the torch on the steel.
I also tried the other copy of mach3 with a fresh made file with the same result.
Are you using SheetCam to generate your G-code, if so you may want to look at this.
I am using sheetcam but can not see the file you posted
So, could someone send me a file for 16ga to test the theory of sheetcam having lost its mind?
I checked that in both copies of sheetcam and they were both zero. One had the material thickness off.
Ok that was just something that popped into my head with your stated problem. But you still may have a problem with the post processor you are using in SheetCam, having some odd movement in it that adds the movement you are seeing. In the post processor there is a group of commands that deal with the Z movement around the start of cut operation, called "On Open Down" see attached. You can look at this by going in SheetCam to the Options tab and then the Machine tab. This is where you select the post processor you want to used, in that menu there is an edit button. If you click on that it will open the post processor for you to look at, scroll down to the "On Open Down" section and see if there is a command like G1 Z .785
There's other lines in but the Z lines are identical in my file.
Could someone send me a cut file for a hypertherm 45xp to try so I can see if there might be some off the wall anomaly in my copy of sheetcam? 16ga mild is what I have on hand.
Keep playing with this thing trying to chew it finer. I ran two files on a dry run (torch off) and the torch stayed down. As soon as I turned the torch on and went to run the file it climbed to .550 before I hit estop.
This is with thc off in mach3
Awesome. Better info than be the manual. Thank you.
Post up the g-code that has this issue.
4x4 Plasma Table
Mach3 with CSMIO/IP-S
CandCNC Feather Touch & LCTHC
Hypertherm PMX 1000
Homemade Rotary Plasma Attachment
Hypertherm PMX 1000
There is, it started with me wanting a file to test and ended with figuring out the issue mostly. The thc voltage was set at 125 while actual is in the 90s causing the continuous rise. Now I'm play with getting the thc voltage right so it maintains the files set cut height.
- 4.5 Star Member
Someone asked you for something but you seem to have ignored it. I would have asked for the same thing.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
You are using sheetcam correct? Right click on the .tap file and select open with. Then select notepad. Copy and paste what is in the text file.
4x4 Plasma Table
Hypertherm PMX 1000
Hypertherm PMX 1000
N0010 (Filename: nc outline.tap)
N0020 (Post processor: Gorilla Machines Plasma.scpost)
N0030 (Date: 03/11/2019)
N0040 G20 (Units: Inches)
N0050 G53 G90 G40
N0060 F1
N0070 S500
N0080 (Part: nc outline)
N0090 (Process: Outside Offset, white, T1: 16 GA Mild Steel 250 IPM 95V)
N0100 M06 T1 (16 GA Mild Steel 250 IPM 95V)
N0110 G00 X0.7621 Y2.3653 Z0.5000
N0120 G31 Z -100 F50.0
N0130 G92 Z-0.0800
N0140 G00 Z0.1500
N0150 M03
N0160 G04 P0.5
N0170 G01 X0.7621 Y2.3653 Z0.0600 F20
N0180 G02 X0.9838 Y2.5916 I0.2240 J0.0022 F250.0
N0190 G01 X3.2184 Y2.6139 F250
N0200 G03 X3.2277 Y2.6155 I-0.0003 J0.0295 F250.0
N0210 G01 X4.0745 Y2.9052 F250
N0220 X5.2831 Y2.9059
N0230 G02 X6.3173 Y2.8903 I0.1288 J-25.8291 F250.0
N0240 G01 X6.3178 F250
N0250 G02 X6.9629 Y2.8253 I-0.0755 J-3.9808 F250.0
N0260 G01 X6.9644 Y2.8250 F250
N0270 G02 X7.1856 Y2.7220 I-0.0533 J-0.4034 F250.0
N0280 G03 X7.3671 Y2.6501 I0.1435 J0.0972
N0290 G02 X7.6539 Y2.5398 I0.0495 J-0.2992
N0300 X7.7349 Y2.2750 I-0.5332 J-0.3079
N0310 G01 Y2.2741 F250
N0320 X7.7497 Y2.1251
N0330 G03 X7.7786 Y2.0985 I0.0294 J0.0029 F250.0
N0340 G01 X10.2788 Y2.0561 F250
N0350 X10.9158 Y1.4765
N0360 X11.3317 Y1.0997
N0370 G03 X12.2383 Y0.3075 I19.5494 J21.4563 F250.0
N0380 X12.5445 Y0.0752 I2.3369 J2.7619
N0390 G01 X12.5448 Y0.0750 F250
N0400 G03 X12.7163 Y-0.0120 I0.4683 J0.7113 F250.0
N0410 X12.8313 Y-0.0273 I0.0841 J0.1923
N0420 X12.8345 Y-0.0266 I-0.0043 J0.0292
N0430 G01 X12.8410 Y-0.0249 F250
N0440 X12.8966 Y-0.0159
N0450 G02 X13.4043 Y0.0279 I1.0261 J-8.9225 F250.0
N0460 G03 X13.6977 Y0.0528 I-0.3340 J5.6700
N0470 X13.9434 Y0.0952 I-0.1530 J1.6207
N0480 X14.0134 Y0.1306 I-0.0285 J0.1431
N0490 X14.0179 Y0.1358 I-0.0199 J0.0218
N0500 X14.0828 Y0.3858 I-0.3171 J0.2158
N0510 G02 X14.0931 Y0.5039 I0.5671 J0.0102
N0520 G01 X14.0933 Y0.5052 F250
N0530 G02 X14.1051 Y0.5381 I0.0892 J-0.0133 F250.0
N0540 X14.1297 Y0.4856 I-0.1344 J-0.0952
N0550 G03 X14.1685 Y0.4093 I0.2010 J0.0541
N0560 X14.2650 Y0.3890 I0.0579 J0.0357
N0570 X14.2711 Y0.3946 I-0.0168 J0.0243
N0580 X14.2960 Y0.4708 I-0.0854 J0.0701
N0590 G01 X14.2973 Y0.4756 F250
N0600 G02 X14.3295 Y0.5262 I0.2753 J-0.1391 F250.0
N0610 X14.6881 Y0.9308 I3.4290 J-2.6790
N0620 G03 X15.0421 Y1.3254 I-3.2367 J3.2599
N0630 X15.1654 Y1.5264 I-0.6276 J0.5231
N0640 X15.1664 Y1.5292 I-0.0272 J0.0117
N0650 G02 X15.2432 Y1.6656 I0.3582 J-0.1117
N0660 G03 X15.2469 Y1.6710 I-0.0222 J0.0195
N0670 G02 X15.2895 Y1.6862 I0.0297 J-0.0162
N0680 X15.3018 Y1.6339 I-0.0694 J-0.0438
N0690 G03 X15.3016 Y1.6302 I0.0294 J-0.0030
N0700 X15.3367 Y1.4719 I0.4188 J0.0100
N0710 X15.4545 Y1.4048 I0.0896 J0.0204
N0720 X15.4570 Y1.4058 I-0.0090 J0.0281
N0730 X15.5448 Y1.4547 I-0.1879 J0.4403
N0740 G02 X16.2250 Y1.6955 I0.8288 J-1.2600
N0750 G01 X16.2264 Y1.6956 F250
N0760 G03 X16.5317 Y1.7577 I-0.4417 J2.9551 F250.0
N0770 X16.6771 Y1.8055 I-0.2161 J0.9015
N0780 X16.6819 Y1.8081 I-0.0115 J0.0272
N0790 G02 X16.8510 Y1.8243 I0.0997 J-0.1501
N0800 G03 X17.0971 Y1.7820 I0.1930 J0.3855
N0810 G01 X17.0981 Y1.7821 F250
N0820 G03 X17.6900 Y2.1136 I-0.1552 J0.9713 F250.0
N0830 X17.7200 Y2.2611 I-0.0773 J0.0925
N0840 X17.7122 Y2.2706 I-0.0263 J-0.0135
N0850 X17.5934 Y2.3067 I-0.1042 J-0.1294
N0860 G02 X17.4661 Y2.3864 I0.0237 J0.1794
N0870 G01 X17.4656 Y2.3870 F250
N0880 X17.4005 Y2.4801
N0890 G03 X17.3670 Y2.4912 I-0.0242 J-0.0170 F250.0
N0900 G01 X17.0032 Y2.3703 F250
N0910 X17.0029 Y2.3702
N0920 G02 X16.7470 Y2.2924 I-1.1138 J3.2045 F250.0
N0930 X16.3211 Y2.3882 I-0.1194 J0.4638
N0940 G03 X16.3180 Y2.3905 I-0.0189 J-0.0227
N0950 G02 X16.0452 Y2.6698 I0.4575 J0.7197
N0960 X16.0411 Y2.7015 I0.0701 J0.0252
N0970 X16.0765 Y2.6773 I-0.1332 J-0.2320
N0980 G01 X16.0770 Y2.6769 F250
N0990 G02 X16.2258 Y2.5556 I-2.6002 J-3.3454 F250.0
N1000 G01 X16.2263 Y2.5553 F250
N1010 X16.2903 Y2.5028
N1020 G03 X16.5265 Y2.3868 I0.2855 J0.2826 F250.0
N1030 X16.5298 Y2.3866 I0.0036 J0.0293
N1040 X16.6509 Y2.4015 I0.0043 J0.4652
N1050 X16.6531 Y2.4021 I-0.0074 J0.0286
N1060 X17.2641 Y2.8710 I-0.3927 J1.1442
N1070 X17.3469 Y3.0139 I-0.5215 J0.3976
N1080 X17.2836 Y3.1357 I-0.0743 J0.0388
N1090 X17.1149 Y3.1496 I-0.1373 J-0.6362
N1100 G02 X16.9838 Y3.1521 I-0.0151 J2.6669
N1110 G01 X16.9828 F250
N1120 G02 X16.6367 Y3.2084 I0.0084 J1.1453 F250.0
N1130 G03 X16.6333 Y3.2092 I-0.0091 J-0.0281
N1140 G02 X16.5938 Y3.2448 I0.0103 J0.0512
N1150 G03 X16.5607 Y3.2924 I-0.0753 J-0.0170
N1160 X16.3457 Y3.3946 I-0.4034 J-0.5717
N1170 G02 X15.9508 Y3.6016 I0.3394 J1.1277
N1180 G01 X15.9502 Y3.6020 F250
N1190 G02 X15.9189 Y3.6422 I0.0601 J0.0791 F250.0
N1200 X16.0813 Y3.6183 I0.0158 J-0.4548
N1210 G01 X16.0826 Y3.6179 F250
N1220 G03 X16.3876 Y3.5673 I0.3642 J1.2526 F250.0
N1230 G01 X16.4360 Y3.5646 F250
N1240 G03 X16.4419 Y3.5648 I0.0017 J0.0295 F250.0
N1250 G02 X16.4927 Y3.5347 I0.0067 J-0.0466
N1260 G03 X16.5892 Y3.3911 I0.1435 J-0.0079
N1270 X16.5944 Y3.3898 I0.0097 J0.0279
N1280 X16.8841 Y3.4520 I0.0623 J0.4150
N1290 X16.9569 Y3.6002 I-0.0340 J0.1087
N1300 G02 X16.9545 Y3.6255 I0.0557 J0.0182
N1310 X17.1692 Y3.7801 I0.2197 J-0.0786
N1320 G03 X17.1789 Y3.7820 I-0.0006 J0.0295
N1330 G02 X17.2048 Y3.7621 I0.0067 J-0.0181
N1340 G03 X17.2047 Y3.7601 I0.0294 J-0.0028
N1350 G02 X17.1925 Y3.6626 I-0.4989 J0.0127
N1360 G01 X17.1924 Y3.6620 F250
N1370 G03 X17.1787 Y3.5761 I0.9841 J-0.2013 F250.0
N1380 X17.2208 Y3.4908 I0.0587 J-0.0241
N1390 X17.2297 Y3.4898 I0.0077 J0.0285
N1400 X17.2877 Y3.5015 I-0.0073 J0.1851
N1410 G02 X17.4673 Y3.4518 I0.0411 J-0.2008
N1420 G03 X17.4717 Y3.4484 I0.0200 J0.0218
N1430 X17.8029 Y3.3284 I0.4485 J0.7208
N1440 G01 X18.0019 Y3.3015 F250
N1450 G03 X18.0262 Y3.3093 I0.0040 J0.0293 F250.0
N1460 G01 X18.3465 Y3.6125 F250
N1470 X18.4837 Y3.7387
N1480 G02 X18.6650 Y3.8900 I1.8125 J-1.9885 F250.0
N1490 X18.6880 Y3.9052 I0.1328 J-0.1751
N1500 X18.7035 Y3.8821 I-0.0209 J-0.0307
N1510 G03 X18.7049 Y3.8776 I0.0289 J0.0060
N1520 G02 X18.7157 Y3.8350 I-0.1739 J-0.0670
N1530 G01 X18.7158 Y3.8345 F250
N1540 X18.7169 Y3.8270
N1550 G03 X18.7263 Y3.7802 I0.3023 J0.0366 F250.0
N1560 X18.7772 Y3.7472 I0.0401 J0.0060
N1570 X18.7833 Y3.7496 I-0.0079 J0.0285
N1580 X18.8081 Y3.7709 I-0.0357 J0.0668
N1590 X18.8515 Y3.8309 I-0.5434 J0.4392
N1600 X18.9697 Y4.1951 I-0.6204 J0.4026
N1610 X18.9215 Y4.5087 I-0.4993 J0.0837
N1620 X18.9149 Y4.5173 I-0.0263 J-0.0134
N1630 X18.5096 Y4.5512 I-0.2251 J-0.2508
N1640 X18.5045 Y4.5472 I0.0158 J-0.0250
N1650 X18.4088 Y4.3041 I0.2312 J-0.2313
N1660 G02 X18.3874 Y4.1709 I-0.4723 J0.0076
N1670 G03 X18.3867 Y4.1681 I0.0282 J-0.0088
N1680 G02 X18.3183 Y4.0758 I-0.1332 J0.0273
N1690 X18.2818 Y4.1203 I0.0167 J0.0510
N1700 G03 X18.2807 Y4.1253 I-0.0293 J-0.0036
N1710 G02 X18.2388 Y4.4329 I0.9356 J0.2841
N1720 G01 Y4.4336 F250
N1730 G03 X18.2253 Y4.6348 I-1.5349 J-0.0016 F250.0
N1740 X18.1575 Y4.7797 I-0.2029 J-0.0067
N1750 X18.1525 Y4.7833 I-0.0197 J-0.0221
N1760 X18.0046 Y4.8110 I-0.1138 J-0.1993
N1770 X17.7845 Y4.6697 I0.0087 J-0.2558
N1780 X17.7813 Y4.6564 I0.0264 J-0.0132
N1790 G02 X17.7395 Y4.6171 I-0.0393 J-0.0001
N1800 G01 X17.7388 Y4.6172 F250
N1810 G02 X17.6245 Y4.6326 I0.0237 J0.6068 F250.0
N1820 G03 X17.6218 Y4.6331 I-0.0067 J-0.0288
N1830 X17.1095 Y4.6556 I-0.3783 J-2.7731
N1840 G02 X16.8792 Y4.6533 I-0.1391 J2.4242
N1850 G03 X16.8742 Y4.6531 I-0.0011 J-0.0295
N1860 G02 X16.7652 Y4.7107 I-0.0140 J0.1053
N1870 G01 X16.7578 Y4.7278 F250
N1880 G02 X16.7387 Y5.3062 I1.6435 J0.3439 F250.0
N1890 G03 X16.7389 Y5.3113 I-0.0293 J0.0041
N1900 G02 X16.7880 Y5.4196 I0.1341 J0.0045
N1910 G03 X16.7939 Y5.4260 I-0.0187 J0.0229
N1920 G02 X16.8158 Y5.4359 I0.0189 J-0.0126
N1930 X16.8222 Y5.4115 I-0.0422 J-0.0242
N1940 G01 X16.8223 Y5.4095 F250
N1950 G02 X16.8152 Y5.2376 I-0.8391 J-0.0518 F250.0
N1960 G03 X16.8327 Y4.9213 I0.6052 J-0.1253
N1970 X16.8351 Y4.9158 I0.0281 J0.0091
N1980 X17.0550 Y4.7774 I0.2395 J0.1366
N1990 X17.1434 Y4.7648 I0.1241 J0.5576
N2000 X17.2324 Y4.8588 I0.0151 J0.0748
N2010 G02 X17.2567 Y4.8845 I0.0204 J0.0051
N2020 G03 X17.2622 Y4.8840 I0.0055 J0.0290
N2030 G02 X17.3802 Y4.8742 I0.0002 J-0.7122
N2040 G01 X17.3809 Y4.8741 F250
N2050 G03 X17.4845 Y4.8642 I0.1615 J1.1389 F250.0
N2060 X17.5901 Y4.8682 I0.0349 J0.4661
N2070 X17.6267 Y4.8868 I-0.0061 J0.0574
N2080 X17.6329 Y4.8975 I-0.0219 J0.0199
N2090 X17.6288 Y4.9453 I-0.0586 J0.0190
N2100 X17.5367 Y5.0729 I-0.4091 J-0.1985
N2110 G01 X17.4699 Y5.1425 F250
N2120 X17.8087
N2130 G03 X18.0268 Y5.1457 I0.0396 J4.7698 F250.0
N2140 X18.0966 Y5.1540 I-0.0097 J0.3814
N2150 X18.1433 Y5.2139 I-0.0014 J0.0493
N2160 X18.1411 Y5.2202 I-0.0288 J-0.0064
N2170 X18.1059 Y5.2687 I-0.1495 J-0.0715
N2180 G02 X18.0410 Y5.3954 I0.1739 J0.1690
N2190 G01 X18.0450 Y5.3945 F250
N2200 G02 X18.1711 Y5.3365 I-0.4487 J-1.1408 F250.0
N2210 G03 X18.2488 Y5.2992 I0.4233 J0.7821
N2220 X18.3274 Y5.3086 I0.0341 J0.0485
N2230 X18.3345 Y5.3243 I-0.0222 J0.0195
N2240 X18.2946 Y5.5249 I-0.3160 J0.0415
N2250 G02 X18.4574 Y5.3168 I-0.6998 J-0.7150
N2260 G03 X18.5543 Y5.1760 I1.1411 J0.6826
N2270 X18.6367 Y5.1078 I0.1686 J0.1195
N2280 X18.6433 Y5.1056 I0.0123 J0.0269
N2290 X18.7482 Y5.1763 I0.0172 J0.0875
N2300 G01 X18.7484 Y5.1776 F250
N2310 G03 X18.7258 Y5.3141 I-0.2244 J0.0330 F250.0
N2320 X18.4151 Y5.7975 I-1.9561 J-0.9156
N2330 G01 X18.1868 Y6.0845 F250
N2340 G03 X18.1637 Y6.0957 I-0.0231 J-0.0184 F250.0
N2350 G01 X5.8468 F250
N2360 G03 X5.8203 Y6.0792 I0.0000 J-0.0296 F250.0
N2370 X5.7050 Y5.7093 I1.1065 J-0.5478
N2380 G01 X5.7048 Y5.7080 F250
N2390 G02 X5.6947 Y5.6516 I-0.3707 J0.0374 F250.0
N2400 G03 X5.6938 Y5.6446 I0.0286 J-0.0074
N2410 G02 X5.6653 Y5.5979 I-0.0537 J0.0008
N2420 G01 X5.5183 Y5.5642 F250
N2430 G03 X5.5133 Y5.5625 I0.0066 J-0.0288 F250.0
N2440 X5.1981 Y5.3762 I0.5562 J-1.3004
N2450 G02 X4.7436 Y5.1647 I-0.6721 J0.8503
N2460 G01 X4.7428 Y5.1646 F250
N2470 G03 X4.2477 Y4.9620 I0.3775 J-1.6290 F250.0
N2480 G01 X4.2465 Y4.9611 F250
N2490 G02 X4.0103 Y4.8359 I-0.6685 J0.9749 F250.0
N2500 G03 X4.0069 Y4.8343 I0.0108 J-0.0275
N2510 G02 X3.8644 Y4.8824 I-0.0491 J0.0894
N2520 G01 X3.8641 Y4.8831 F250
N2530 G03 X3.7329 Y4.9822 I-0.1605 J-0.0760 F250.0
N2540 X3.7294 Y4.9826 I-0.0049 J-0.0291
N2550 X3.4228 Y4.8602 I-0.0175 J-0.4010
N2560 G02 X3.2928 Y4.7609 I-0.9335 J1.0885
N2570 G01 X3.2922 Y4.7606 F250
N2580 G02 X3.2197 Y4.7191 I-0.2482 J0.3501 F250.0
N2590 G03 X3.1592 Y4.6695 I0.0594 J-0.1343
N2600 X3.0918 Y4.5284 I0.3093 J-0.2344
N2610 G01 X3.0908 Y4.5248 F250
N2620 G03 X3.0899 Y4.5189 I0.0286 J-0.0075 F250.0
N2630 G02 X3.0133 Y4.4132 I-0.1198 J0.0062
N2640 X2.8570 Y4.3822 I-0.2442 J0.8217
N2650 G01 X2.8560 Y4.3820 F250
N2660 G03 X2.4355 Y4.2238 I0.1359 J-0.9993 F250.0
N2670 G01 X2.4347 Y4.2233 F250
N2680 G02 X2.2290 Y4.1000 I-0.8978 J1.2651 F250.0
N2690 X1.5160 Y3.9068 I-0.9669 J2.1550
N2700 G01 X1.5151 Y3.9066 F250
N2710 G03 X1.2138 Y3.8505 I0.4421 J-3.2081 F250.0
N2720 X0.7619 Y3.5100 I0.1025 J-0.6063
N2730 G02 X0.6471 Y3.3563 I-0.5376 J0.2816
N2740 X0.3126 Y3.2235 I-0.3821 J0.4746
N2750 G03 X0.3096 Y3.2231 I0.0023 J-0.0295
N2760 G01 X0.2563 Y3.2134 F250
N2770 G03 X0.0558 Y3.0899 I0.0128 J-0.2455 F250.0
N2780 X0.0539 Y3.0860 I0.0257 J-0.0147
N2790 X-0.0006 Y2.8408 I0.7543 J-0.2963
N2800 G01 X-0.0293 Y2.6150 F250
N2810 G03 X0.0003 Y2.5817 I0.0293 J-0.0037 F250.0
N2820 G01 X0.9838 Y2.5916 F250
N2830 G02 X1.2100 Y2.3698 I0.0022 J-0.2240 F250.0
N2840 M05
N2850 G00 Z0.5000
N2860 M05 M30
N0050 G53 G90 G40
N0060 F1
N0070 S500
N0130 G92 Z-0.0800
N0140 G00 Z0.1500
N0150 M03
N0160 G04 P0.5
N2120 X17.8087
N2840 M05
N2850 G00 Z0.5000
N2860 M05 M30
