Another problem in getting my DIY plasma cutter working.
I created a simple test program (2 circles) in an evaluation copy of Sheet-cam and when I try to load it in my licensed copy of Mach 3 I get a message saying Generating Tool Path and that's as far as it ever gets.
I've listed the program below and any help would be appreciated.
N0010 (Filename: 12 in circle.tap)
N0020 (Post processor: Mach3 plasma.scpost)
N0030 (Date: 09/03/2020)
N0040 G20 (Units: Inches)
N0050 G53 G90 G91.1 G40
N0060 F1
N0070 S500
N0080 (Part: 12 in circle)
N0090 (Operation: Inside Offset, LAYER_1, T1: Plasma, 0.0591 in kerf)
N0100 M06 T1 F3.937 (Plasma, 0.0591 in kerf)
N0110 G00 Z1.0000
N0120 X4.1256 Y9.9040
N0130 Z0.1181
N0140 M03
N0150 G04 P0.5
N0160 G01 Z0.0591 F3.937
N0170 G02 X4.0296 Y10.0000 I0.0000 J0.0960
N0180 X4.0296 Y10.0000 I5.9704 J-0.0000
N0190 M05
N0200 G00 Z1.0000
N0210 X11.7643 Y17.3153
N0220 Z0.1181
N0230 M03
N0240 G04 P0.5
N0250 G01 Z0.0591
N0260 G02 X11.6683 Y17.4113 I0.0000 J0.0960
N0270 X11.6683 Y17.4113 I1.4704 J0.0000
N0280 M05
N0290 G00 Z1.0000
N0300 M05 M30
Program won't run
Re: Program won't run
There is a limit to the number of lines that Sheetcam will generate with the non licensed version about 250 if you go over that you will get a message. This G-code does work I use the house PC no table attached, but you speed is so slow it appears not to move. Edit the G-code on line N0160 so the F is about 60 not 3.937 and it should look better. Mach only changes speed with a new command for a speed change so only one speed setting in your G-code affects the whole G-code. You may have a slower Z and then faster X & Y for cutting.
My problem is the program won't load.
I've attached a screen shot of what I mean. The Generating Path is all I get and it never goes beyond that point. A tool path is never rendered on the display.
Hopefully someone has an idea on what this might be.
- Attachments
- Screen 1.jpg (83.83 KiB) Viewed 339 times
