Estop changes the way the table functions.
- trucks1948
I moved my whole set up. Then had a hard drive go bad.I installed a new Mach3 disc and liscence.Now I do not get correct table movement. When I use my keyboard arrow keys. Most the time the z will up and down, most of the time the x and y don't move. But when i cycle the estop things change. It may work on the z or if I cycle again the x- may work or maybe the y+.When i say they work ,the z works as it should the x and y try to work. The hotkeys have been set as have the ports and pins.any ideas will be appreciated. Thanks.
Re: Estop changes the way the table functions.
I have seen this before don't know why but this fixes it.
- trucks1948
Thanks but i don't have that checked.
I would try reloading Mach 3 you may want to get a fresh download from their site, I use version 067.
I would also rechech the motor output in the ports and pins table. You pins may be different for step and dir.
post your XML profile you will need to zip it or change it's extension to upload
- trucks1948
Thanks guys i think we have found a bad board
