I'm in the process of building a new table and have been researching what controller to go with. I've built a few tables in the past and have used Flashcut and CandCNC (w/CCNC).
The biggest issue I have with Flashcut is the initial cost and the cost of add-ons. CandCNC with CCNC was reasonable on the cost side of things, but with no previous Linux experience, I trouble shooting OS issues was a struggle.
Here are the controllers I've been looking at:
UC300ETH w/UCCNC. Neuron has a THC the integrates into UCCNC, but I've come across some threads of issues getting the THC units due to customs. I know Proma THC will work with UCCNC, but I want the THC integrated into the UCCNC screen.
Vital Systems ArcPro. This seems like a professional system with integrated THC, but in researching there seems to be a bunch of negative threads on Mach4. So I've very hesitant.
MyPlasm CNC. This comes with its own THC. Overall it seems very limited on settings and as far as I can tell it can only control a torch, no plate marker.
I'd appreciate hearing input on either the systems above or ones I may have over looked. The main requirements are integrated real time THC and the ability to add tools such as a plate marker.
Best suited controller software?
Re: Best suited controller software?
I cannot give you an absolute answer but tell you what I have done the covers some of you concerns. First the use of plate marker (and other add ons) is more in the Generation of the G-code rather then the controller. Many controller will follow what the G-code tells it to do. I have used Mach 3 in the past, and looked at Mach 4. I now use a UC400ETH and it works very well with the different add ons (router, drag knife diamond scribe, and THC) I use. I an unsure of what you mean "issues getting the THC units due to customs" are you talking about out of country shipping problems? I assume you are saying you want THC integrated into the screen similar to what CandCNC and others do. I find that nice but not a deal breaker for me, making the settings on an external unit before I do the cutting that objectionable. IMHO
neuron lite or pro is the best, only compared to hypertherm's ArcGlide. A separate point is Andrew's remote backup and support, simply THE BEST.
Many people have converted to LinuxCNC's plasmac config and have never looked back. The latest GUI configuration QTPlasmac is purpose built for plasma. There is a seperate section on this forum for plasmac that might be worth reviewing.
