Hello Everyone,
I was wondering if there was a way to get a proper copy of my designs in design edge to show or email my customers.
While in design edge, I can select my desired item> hit 'F6' so my item goes full screen, then hit 'Ctrl W' and it takes me to a black and white version of my image/item. To me, from there I should be able to save it as a JEPG or PDF etc. The only option I seem to get it to print it.
I would love to be able to easily save the image and forward it to a customer as a proof or save it for a catalog picture.
Any ideas out there?
Thank you in advance.
Arlo
Digital copies of my designs
Re: Digital copies of my designs
You can take a screen shot. Works for me
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Durma Brake
10x40 lathe
2-Miller 255
Miller XMT350MPA
12 Ft Durma Brake
- ROKCRLER
Hi Arlo,Moonlight31 wrote: ↑Tue Aug 24, 2021 3:58 pm Hello Everyone,
Arlo
Here is an example of how I do it.
Use "Ctrl W" to view print preview. Print as pdf View pdf (I use Firefox, but Adobe Reader works as well) I use PDF995 to print to pdf format. This is a free download here.
http://www.pdf995.com/
My computer also offers the option to print to Microsoft pdf printer. This one does a "closed path fill". My go-to method is usually to do a screen shot. Print Screen, past into Paint.net, crop if required and save as PFD.
Crop/resize Here is the pcm file I started with.
Here are the pdf files.
- SegoMan DeSigns
Impose your business logo over the proof so somebody don't run with your design and hard work..
Not a bad idea! And something I wouldn't have considered doing. I guess I am too trusting. But as we all (at least most of us) know, it is easy enough to edit out a business logo or watermark.SegoMan DeSigns wrote: ↑Wed Aug 25, 2021 12:29 pm Impose your business logo over the proof so somebody don't run with your design and hard work..
Here is an example.
Before editing After editing using Paint.net by simply adjusting contrast and brightness
Thank you all!
