Dear Valued Member's, I am New in SheetCAM and this forum. Can you please help me to resolve my problem.
I'm having an Issue with my Newly Started CNC Plasma Cutter Machine projects. I have Installed SheetCAM TNG 6.0.28 for My Mach3 Non THC Plasma Cutting machine. I imported DXF file which is OK. The DXF works fine on LazyCAM.
But its generating Incomplete G-Code On SheetCAM.
N0010 (Filename: Reza-Faruk_01_03-23_1.tap)
N0020 (Post processor: Mach3 plasma.scpost)
N0030 (Date: 01/03/2023)
N0040 G21 (Units: Metric)
N0050 G53 G90 G91.1 G40
N0060 F1
N0070 S500
N0080 (Part: Reza-Faruk)
N0090 M05 M30
When i try to simulate the Job it finished with Error...
Post processing...
Part:Reza-Faruk
Outside Offset, Layer_1, T1: Plasma_Mach3_LGK100
Warning: WARNING: Feed rate is zero
Post processing completed with 1 warnings
I think, I followed every Configuration Steps. I am using "Mach3 plasma Post processor"
SheetCAM Mach3 Plasma Cutter G-Code Issue.
Re: SheetCAM Mach3 Plasma Cutter G-Code Issue.
Do you have a feed rate in the tool that you are using, Your sample G-code shows a F of 1 and no axis for the move command.
In Mach 3 under the MDI page in the input box type G1 X 3 f 50 enter key that should move the X 3 inches/mm (your choice of measurement) at about a fair speed.
Check the feed rates in your cut operations. Additionally check the feed rate and plunge rate in your tool definition.
Tnx for Replaying,acourtjester wrote: ↑Wed Mar 01, 2023 1:02 pm Do you have a feed rate in the tool that you are using, Your sample G-code shows a F of 1 and no axis for the move command.
I am using a Offline Mach3 Software for simulation and "G1 X 3 f 50" Command working Fine under MDI. I just want to Generated a G-Code from SheetCAM and Run it on a live machine. G-Code Generated on LazyCAM Just working Fine on Machine for me.
My Tools configuration is as bellow.. My Operation configuration is as bellow.. Tnx in Advance
Please see my above post for details..Les Newell wrote: ↑Wed Mar 01, 2023 1:31 pm Check the feed rates in your cut operations. Additionally check the feed rate and plunge rate in your tool definition.
Is your SheetCam licensed? I think I've seen this come up before and it was a licensing issue. I'd either post this on the SheetCam forum or email Les at SheetCam.
Tnx For Replaying.
Is it a license Issue ?! I have Downloaded the Copy of SheetCAM Randomly sourced from internet...
Tnx in Advance
Go to SheetCam.com & download the latest version.
In SheetCam go to Help->about. If you send me the license id in an email or PM I'll check it for you.
