Anyone have any offroad tabs or brackets?
Building a new offroad buggy and was looking for some cool trick tabs or brackets.
Thank you for any help with this search!
Re: Anyone have any offroad tabs or brackets?
What type and size of brackets do you need?
http://www.PenningtonFab.com
Torchmate 3 with Accumove 3
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Lincoln wirematic 250
Eastwood 175 with Spoolgun
Eastwood 135 Mig
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Eastwood 135 Mig
I plan to run coilovers with Ballistic Joints. The bolt holes will be 1/2 for coilovers and 3/4 5/8 or 9/16 on all the tabs. I have not yet ordered my parts so I can work or rework some parts really would just like so ideas if you have any?
Thank you!!
Thank you!!
x2
im swapping axles and could really use some 4 link tabs/brackets, shock mounts, coil pads, truss,...pretty much anything that anyone's will to share!
Nalin Manufacturing, LLC
Hypertherm Powermax 85
Bulltear Starlab 4'x8'
Try here but for some reason i cant get on it tonight. www.fabricatorsfileexchange.com
Hey John
I tried that website and could not get on ether came up with an error massage. Are you sure that is the corect site add.
Rod S in AZ
- Chopper John
That is the right address, I had it saved and can't access it either.
Chopper John
Mad City Cycles, Inc.
I as well had no luck with that site. Thank you for trying to help out!!
what axles are you useing? I got brackets for dana 60 14 bolt link brkt ect. I'll post for you
60 front 14b rear!bogger44 wrote:what axles are you useing? I got brackets for dana 60 14 bolt link brkt ect. I'll post for you
found this site:
http://www.trailslesstraveled.com/resources/cadlibrary/
still like to see what 14b/d60/link stuff you have
Nalin400m..............Thank you for the great site!!!
no one, really?
d60 14 bolt this should get you started you pair the link brackets togeather to achieve your angle and you can change the circle diamiter for what axle diamiter you are working on
14 bolt
14 bolt
If you need anyothers If you give dimentions that you want you want I can draw them for you.
D60 rubicon express joint
shock tabs
for 1.5 tube
for 1.5 tube
Wow, now there is a "good" answer to your question!
Thanks a bunch,
WSS
Thanks a bunch,
WSS
BOGGER44.................Thank you a bunch for those files!!!!!!
Yes, I do!!! Thank you!
Here's a bunch you can try. Just got them myself and haven't had a chance to try them yet, so if anyone tries them let us know how they turn out.
alaska66 wrote:Here's a bunch you can try. Just got them myself and haven't had a chance to try them yet, so if anyone tries them let us know how they turn out.
can any one covert these to DFX ?
they are ziped to make the files smaller download and unzip with your windows winzip or whatever
- DHPmike
I have literally hundreds of tabs and brackets. I have all different sizes and style...
i dont see themDHPmike wrote:I have literally hundreds of tabs and brackets. I have all different sizes and style...
- DHPmike
The little ears on the end of these tabs are useless. they burn away welding or are completely useless as far as strength goes.
Heres a sample of some of mine. I build tubular control arms, watts links, 4 links, and all kinds of parts for air ride suspension.
Let me introduce myself so you guys know where Im coming from. I didnt see a new person section.
My name is Mike and I work at Integrated Armor Systems (http://www.integratedarmor.com) and I am the fab shop supervisor.
We have a 54,000 sq ft facility in Dallas Texas. We build armored vehicles such as SWAT trucks, Suburbans, F-350 trucks, Mercedes sedans etc. We build everything in house. We make all the door hinges, bulkhead doors and all interior armoring in house. We have a Plate Pro 6'x18' table running a Hypertherm powermax 1650. It runs an icnc controller and Promotion nest and promotion cut. We draw everything in Solidworks dwg editor.
We also build parts bumpers, grille guards, headache racks and other parts for http://www.riggratt.com. I get to have lots of hands on in the design process but we have to keep our designs pretty main stream. We dont get to do anything real far out there.
I have a small business I run out of the same facility called Dallas Hotrod Parts (http://www.dallashotrodparts.com) and I build all kinds of suspension parts. I have hundreds of drawings for all kinds of things. some I consider proprietary. Heres a few examples of my generic tabs.
Michael White
Dallas Hotrod Parts
Dallas Hotrod Parts
