3 D Stars
Re: 3 D Stars
DXF file please this is the sharing form!
Looks great
Looks great
Re: 3 D Stars
awesome star ! but im not seeing the dxf if anyone could post it i would greatly appreciate it. i wish i was able to contribute but im still a newbie with the file drawing maybe hopefully someday i can return the favor.
Re: 3 D Stars
If you do a search their are several basic 3d stars in the file sharing section and you can simply add the other stars and circles or whatever you want to it and build your own version and then you can share it I just uploaded a 3d star a couple weeks ago so go find it and modify to your likings.
I do agree the original one in this post was very cool looking but why on earth would you want to do the exact same thing when you can customize your own in about 10 minutes
Re: 3 D Stars
I found the post with some info about the 3 d star here is some info I pulled from that download that may help.
See attached image with dimensions. Next DXF is of one part that can be opened in SheetCam and others added and aligned as needed. Along with adding cut outs inside as you like.
- Scott Briggs
Re: 3 D Stars
Scale to size bend to match, and wallah.
5X10 PlasmaCam
Hypertherm 45
Miller 252
Miller 212
Lincoln 215
Lincoln 185 Tig
100 ton Break Press
http://www.scooterbiltmanufacturing.com
Hypertherm 45
Miller 252
Miller 212
Lincoln 215
Lincoln 185 Tig
100 ton Break Press
- GoingCustom
Re: 3 D Stars
I had the dxf up for a long time in the original post, but I found two different companies claiming this file and another original I posted (and have since taken down) to be their own design. Or at least until I said something to them. I don't mind if files are used, but at least give credit where it's due or at the very least, don't claim them to be your own if you didn't draw it. It's a huge reason why I'm not on the forum very often anymore.Patrick Waite wrote:Gee travis all them picture and No DFX file of the one you made. wow
Re: 3 D Stars
Does anyone have the file for the 3D star with the swirls and stars in it? Thanks
Re: 3 D Stars
Great job. thanks for sharing!
Re: 3 D Stars
I made mine using the formula on the math link. Worked perfect for me. It looked tougher to figure than it really is.
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
PlasmaCam DHC2
MADE IN USA
Re: 3 D Stars
Thank you for sharing sirScott Briggs wrote:Scale to size bend to match, and wallah.
Re: 3 D Stars
Thank you kindlyacourtjester wrote:I found the post with some info about the 3 d star here is some info I pulled from that download that may help.
Re: 3 D Stars
Here is the file I used one is for the single point parts and the other is for 5 points parts.
I'm not crafty enough to bend the parts so I cut each piece for the points and tack them before assembly.
- Capstone
Re: 3 D Stars
Thanks for reviving this thread. nice looking piece
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Re: 3 D Stars
Thanks for the pattern!
Re: 3 D Stars
Can someone help I don't see the file for the 3D stars
Re: 3 D Stars
If you are not a paying member you cannot see or download the files.
For the fee of $20 per year you can download all the posted files from here from the start in a singular function. (one at a time).
It may take a day for you membership to take effect
Re: 3 D Stars
where is the file? thanks if someone has the 3d star file
Re: 3 D Stars
There are both DXF and SVG files above
Re: 3 D Stars
I'll add these. Drew them for Downtown Bozeman's Christmas decorations. Set to fly over main street again on Monday!
Re: 3 D Stars
Is this file still available? I don't see the dl anywhere.
- Larry83301
Re: 3 D Stars
Just scroll up and you will find several files on this page.CHAOTiC WAYz wrote:Is this file still available? I don't see the dl anywhere.
http://plasmaspider.com/viewtopic.php?f ... ead#p77095
http://plasmaspider.com/viewtopic.php?f ... ad#p107286
Re: 3 D Stars
Larry83301 wrote:Just scroll up and you will find several files on this page.CHAOTiC WAYz wrote:Is this file still available? I don't see the dl anywhere.
Wow, apparently i was on the wrong page. Didn't see any of these. thanks.
Re: 3 D Stars
I downloaded the first DXF file in this thread. What is the distance from the table to the middle of the star? Just wanting to figure out how to make it all fit together.
Thanks.
Thanks.
TruCut 5x10
Victor Plasma
Thermal Dynamics
Sheet Cam
Rhino3d
Bobcad
Victor Plasma
Thermal Dynamics
Sheet Cam
Rhino3d
Bobcad
