Was looking for a dxf of the bender that uses jd2 dies, didn't come up with one, however I did run accross the drawings for it and made a dxf,
Here are the drawings
Jpg of my drawing(picture rus out of the screen, I'm not sure how to fix it)
and the dxf
JD2 bender dxf
JD2 bender dxf
Re: JD2 bender dxf
Sweet! Thanks... Have you cut this out yet?
Re: JD2 bender dxf
Thank you for posting. I do appreciate it very much!
Re: JD2 bender dxf
I used this DXF when making my bender...so it does work. I changed things up a bit since I wanted a vertical bender, but the important parts (hole locations, etc) are all correct.
Re: JD2 bender dxf
I've been wanting to switch my JD2 bender to a vertical style for more room in the shop. Care to share the file for your vertical setup, it looks great!
Eric
Eric
Re: JD2 bender dxf
I too have a JD2 bender I was wanting to change to a vertical style. I noticed when trying to lay it out that I thought it would need to set at an angle like your version. I would greatly appreciate it if you were willing to share your file.
Tony
Tony
Re: JD2 bender dxf
Ha, sweet, I haven't gotten around to building mine, I'm glad it worked for you. I'll download your files when I get home.
Re: JD2 bender dxf
What’s the size specifics of material
