FIRE PIT
- Lithics
FIRE PIT
I've seen a lot of fire rings & pits on here....which they all look impressive, but has anyone seen one like this
Its cut out of 1/4" SS
Plasma777
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
Re: FIRE PIT
That's cool!
- Lithics
Re: FIRE PIT
If its made out of thick matl. like 1/4" the hook on top needs to be wider. I made the hook on mine a 1/2" wider, which makes it lay down further. There is 5 pcs to a set, watch your hands it loves to pinch them trying to put it together. Best bet have someone help out.
- Attachments
- Fire Display.pcm
- (34.69 KiB) Downloaded 480 times
Plasma777
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
- larrycameron44
Re: FIRE PIT
Lithics wrote:If its made out of thick matl. like 1/4" the hook on top needs to be wider. I made the hook on mine a 1/2" wider, which makes it lay down further. There is 5 pcs to a set, watch your hands it loves to pinch them trying to put it together. Best bet have someone help out.
Thank you muchly , excellent design
Does anyone have the capacity to convert this to a DXF please?
NZ
- Lithics
Re: FIRE PIT
See if this works
- Attachments
- new fire display.dxf
- (15.2 KiB) Downloaded 936 times
Plasma777
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
Re: FIRE PIT
i get a blank screen
- JJsCustomDesigns
Re: FIRE PIT
Scroll out. Its there. I opened it in Corel4. it was above and to the right of the work area. Thanks for the conversion, btw.
PM me with details
PM me with details
- steelfx
Re: FIRE PIT
Was that cut with plasma? Beautiful Edges. No kerf slant or lick marks....very impressive!
- Lithics
Re: FIRE PIT
No it was cut on a 6000 watt laser. Where I work we have 2 lasers 2800 watt & 6000 watt. We bought a 400 amp, dual head Messer True Hole plasma, table is 10 x 20 able to breeze thru 2" steel, 1.5" stainless and alum. On our plasma you barely see the kerf. The slag knocks rite off. For example if we cut 1" steel feed rate is 86" per min, a 1" hole looks like it was drilled out and the edges we keep within a 1-2 deg angle. I'll dig around for pics of the cut samples we've done
Plasma777
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
- steelfx
Re: FIRE PIT
Sounds like you really know your stuff. Is your plasma system high-definition or does it used compressed air?
I have to cut 3/8" mild steel at 20ipm, so your equipment is awesome! What's the IPM on the big laser for 1/4" steel?
- Gamelord
- 4.5 Star Member
Re: FIRE PIT
That is totally awesome, thanks for sharing.
Torchmate CAD
Torchmate CAD
Re: FIRE PIT
got it now cheers jj
nice fire pit cant wait to cut it
- Lithics
Re: FIRE PIT
You'll have more fun putting it together. It took me a couple try's before i got it, but the first time i think i woke half the neighbor hood up at midnight. It doesn't help I live in town nor dropping one pc on the cement pad.....what a ting that wasfergy wrote:got it now cheers jj
Plasma777
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
- Lithics
Re: FIRE PIT
The plasma is a high def, it uses a couple diff gasses n air. On the laser for 1/4" its around 100 ipm, depends on the grade of steel.steelfx wrote:Sounds like you really know your stuff. Is your plasma system high-definition or does it used compressed air?
Plasma777
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
- steelfx
Re: FIRE PIT
100 IPM on .25" steel. Impressive. If I ever win the lottery, I gotta get one of those! Cheers!Lithics wrote:The plasma is a high def, it uses a couple diff gasses n air. On the laser for 1/4" its around 100 ipm, depends on the grade of steel.steelfx wrote:Sounds like you really know your stuff. Is your plasma system high-definition or does it used compressed air?
Bill
- Lithics
Re: FIRE PIT
LOL I hear ya there.
Plasma777
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
Re: FIRE PIT
Totally WOW! This is going to be a big surprise for my husband!!!
Re: FIRE PIT
How big is this pit from side to side once its assembled?
Re: FIRE PIT
I showed this pit to one of my teaching partners and he said call and get a price on 1/4" stainless I want one of those. The supplier I use can only get 4x8 sheets, it was only $865.00 Teaching partner said he didn't need one after all!!!
Randy Dobbins
Welding Teacher Humble ISD
- Lithics
Re: FIRE PIT
Very few people will buy it if made from 1/4" ss. At the time I cut mine a couple of people wanted one. 10 GA ss price was $550 n they said hell no....lol. So I priced it out of 10 GA steel that was $150-200. Hate to see wat mine would of cost.
Plasma777
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
Re: FIRE PIT
Lithics wrote:Very few people will buy it if made from 1/4" ss. At the time I cut mine a couple of people wanted one. 10 GA ss price was $550 n they said hell no....lol. So I priced it out of 10 GA steel that was $150-200. Hate to see wat mine would of cost.
How well does the 10g steel resist warping? Seems thin
Jason
4x8 TM2
Themal Dynamics 151
Miller 250 syncrowave
Hobart 210
4x8 TM2
Themal Dynamics 151
Hobart 210
- Lithics
Re: FIRE PIT
My boss made his out of 10 GA stainless, as far as he told me it hasn't warped yet. I don't think your getting the fire hot like a bond fire or as big as some of those fire rings. The fire stays with in a 20" x 20" area, as it burns the coals n ash work towards the middle n drop out the bottom. One thing that I love about it is I can start a fire right after a rain, my last fire pit came from Lowes it was a bowl with some holes to let water or ash out. After a good rain it was overflowing with water
Plasma777
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
PlasmaCam
SolidWorks 2012
SolidEdge V18
Pronest
Corel Draw x4
Re: FIRE PIT
Thanks that's a sweet design. I just cut it
Re: FIRE PIT
i've been wanting to cut this,thanks for the file!
Re: FIRE PIT
I have been wanting this file aswell cheers for the share
