Primeweld Cut60 Not initiating arc?
Discussion forum for RazorWeld, Everlast, and all other plasma cutters.
AdamE
Post by AdamE »
Ran into a issue with my setup not arcing. Air solenoids and everything works fine it seems but no plasma arc. Havent been able to find a fix, machine is not even 2 months old. Changed all consumables and that did not help.
Any suggestions would be great. Its a Primeweld Cut60 with the torch that comes with it
AdamE
Re: Primeweld Cut60 Not initiating arc?
Post by AdamE »
Primeweld called me back for troubleshooting very quickly. Went through some steps to correct the issue and it turns out i had something hanging up the blowback start, so made sure that it was going through its travel feely and bumped up the pressure going into the machine a little bit and were back to cutting.
Thanks for posting the fix, it may help another member in the future.
weldguy
Post by weldguy »
Gotta love those issues that are easy to fix! Glad to hear you’re back up and running. Thanks for posting your solution.
Return to “RazorWeld, Everlast, & All Other Plasma Cutters”
