DTHC-IV to DTHC-V upgrade
BRadix
Post by BRadix »
I just received a New DTHC-V card and I'm not sure if I got the right card. I do not want to install it until I'm sure. I am switching from a DTHC-IV. I requested the DTHC-V with Ribbon cable option. How does the DTHC-V connect to the UBOB? What I was able to find is it should connect through the 16pin ribbon cable (or direct with EBOB). What is the difference between the 2 DTHC-V card options? The card that I received will not connect to the ribbon cable.
Re: DTHC-IV to DTHC-V upgrade
You may be best to contact C&CNC direct on this question. Certainly curious to know what you find out if you could post back.
robertspark
Post by robertspark »
tom comes on here from time to time, but the candc forum is probably where you'll get the best and fastest answers.
https://www.candcnc.net/supportforum/index.php
actually scratch that, as I see you have an answer.
https://www.candcnc.net/supportforum/vi ... =24&t=3172
(you'll need to register there for a look).
Post by djreiswig »
Return to “CandCNC Forum”
