Cut (4) of these pipe stand off brackets out of 16 gage stainless steel to install a radiant floor heating system in my shop. Here is a dry fit of my plummers nightmare. My plasma cutter is handy to have! This will be cool.....I mean warm.
Dave Hanks
Pipe stand offs
Re: Pipe stand offs
Such a GREAT IDEA!! Thanks for sharing it.
- dgeorgester
Re: Pipe stand offs
isn't it nice to have great tools to do these little jobs? I find it makes life a bit easier... "we'll just cut something quick on the plasma. Here you go!"
Re: Pipe stand offs
Yep, it is nice to be able to make simple things like these. Got lucky on these......(2) of them were 1.12" short and they worked out perfect because of the staggering of the hot and cold manifolds. Somebody up there is watching out for me.
Dave Hanks
Dave Hanks
Re: Pipe stand offs
I painted these standoff brackets with a rattle can. Going to pressure check it shortly.....winter is just around the corner. Love pex tubing! Plan on charging batteries with a wind generator to run the water heater and circulating pump. The hybrid water heater has WIFI (crazy ain't it?) and draws only 5000 watts. Any ideas on a wind generator system? Thanks
Dave Hanks
Dave Hanks
Re: Pipe stand offs
That'll be so nice to have! Some day when I build an actual shop, I'd like to heat it with waste oil. I think that I could have it both ways, if I wrap a copper coil around the heat exchanger, and then plumb it through the floor, I think that it would heat the air, and keep my cement slab above freezing a lot easier than if I was to just have a furnace running by itself
Re: Pipe stand offs
I wrapped the 6" floating slab with the equivalent of 2" of the blue foam and my shop is all 2" x 6" outside walls and rafters.....best investment I have ever made. Takes very little to heat and cool my 1500 square foot man cave.TrinityFabworks wrote: ↑Mon Sep 16, 2019 8:02 am That'll be so nice to have! Some day when I build an actual shop, I'd like to heat it with waste oil. I think that I could have it both ways, if I wrap a copper coil around the heat exchanger, and then plumb it through the floor, I think that it would heat the air, and keep my cement slab above freezing a lot easier than if I was to just have a furnace running by itself
Dave Hanks
