To Paint or not to Paint Question
topkote
Post by topkote »
Good afternoon Folks,
I'm getting ready to fire up my new table for the first time. Before I do, for the occasional user, does it make sense to paint the water table surface? I realize the slats are going to get cut up but what about the table pan itself. I plan on draining off the table into a 55 gallon drum when it's not in use for a few days. Is it a waste of time / money to paint it? I will be using a commercial quence for the water.
Thanks in advance,
Mike
WyoGreen
Re: To Paint or not to Paint Question
Post by WyoGreen »
I painted my water pan with a zinc rich paint. My slats I left plain, and I drain my table every night into a 55 gallon drum under the table. After saying all that, I have not had any problem with rust either on the pan or the slats. I use washing soda in the water so that may have some influence on the rust.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
topkote
Post by topkote »
Thanks for the response. Mike
SegoMan DeSigns
Post by SegoMan DeSigns »
My 2x2 table has been in use over 5 yrs, with a little buffing from the wire wheel the bare metal still shines. Laundry soda works..
The 6x12 is still on its first set of slats..
My 4x4 water tray has been in service now for about 5 years. It is constructed from 11 ga. cr steel, and I painted the outside only - and left the inside in bare metal. The water additive I use does have some anti-corrosion properties, and I think this has helped to minimize the rust.
TJS
Post by TJS »
i painted mine with POR15 on inside and outside. Total garbage. Peels off in sheets. I might try bedliner on the inside on my next clean out. However I am going to make a holding tank as well.
