Hello From Ohio
Hello From Ohio
just got my new 5x10 plasma table. love it so far. I am use to using a industrial table. the programs are so much easier to use.
sheetcam sucks to use , I can use it just take so long to prep a part to cut. I use Autocad 17LT to make the dxf , have for years. I dont know what the cam programs are in the table at work . its old... 13x 25 water table. but im sure Ill get use to it.
Well thanks for adding me to the group ,
Re: Hello From Ohio
Welcome. I think SheetCam works pretty well. Once you have your tools set up it shouldn't take much to import a drawing, nest it, apply the correct operations and post process. What are you having issues with?
Re: Hello From Ohio
welcome to the group
what do you not like about sheetcam that you like about your new 5x10.
what does it use to generate the gcode?
Re: Hello From Ohio
Here is a site that has many video about SheetCam that will help you learn it, many here use it for all their work.
https://www.youtube.com/user/arclightdynamics
Re: Hello From Ohio
sheetcam generates the G code? correct..robertspark wrote: ↑Sun Jul 12, 2020 4:56 am welcome to the group
Re: Hello From Ohio
SHeetcam crashes evey time I close out of it. it seems to work fine other that that
Re: Hello From Ohio
yes thanks. ive probably watched all of then more that once.acourtjester wrote: ↑Sun Jul 12, 2020 9:36 am Here is a site that has many video about SheetCam that will help you learn it, many here use it for all their work.
Re: Hello From Ohio
my channel and the table I just put in the shop
Re: Hello From Ohio
Let the fun begin your ready
If SheetCam is still having a problem you may see if you can hook up to the internet and have it update to be sure you have a good load.
Or do a download to a USB stick and reload on the shop PC, make sure you have the License.camlic copied so you don't lose it.
Re: Hello From Ohio
which version of sheetcam are you running?
Stable or development release?
https://www.sheetcam.com/downloads
Re: Hello From Ohio
Stable 6.0.30robertspark wrote: ↑Thu Jul 16, 2020 9:14 am which version of sheetcam are you running?
