Hi all,
Happened across this forum and thought I would join up. I do a lot of fabrication and sheet metal work but only as a hobby. Very much into aluminium boats.
Hello from Australia
Re: Hello from Australia
Welcome to the site! What do you have for a cutting table? I imagine a good size if your building aluminum boats!
- 4.5 Star Member
Hi Rabbar,
so what's your interest in boats. Are you into fishing or other boat activities.
What's the biggest size and thickness you expect to cut, i.e. do you make tinnies or something much bigger.
Have you been using air hand plasma so far for cutting your pieces ? I've never cut aluminium myself but heard air plasma can leave a bit of a scraggy edge.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
