Hello
Hello
Hello I’m new to cnc just built a 5x5 and was having an issue I couldn’t work out and thought someone with more experience may have had or herd of this problem I’m using Inkscape sheet am and mach3 my machine cuts great until it to the end of a cut and the torch is turned off before the end as if they were all open paths
Re: Hello
Welcome aboard, many here happy to help, with a varied group there is lots of experience to other find what is causing their problems.
What you may have is there is a small opening in the drawing, when I think this is happened I use SheetCam to help finding them. When you have the drawing and you are doing the cut plan, click on the icon for showing the start position. Each start position is indicated with a s with a number, if you cannot change the position of each start to another location on the cut path it is an open path. Then you can go back to Inkscape and close the gap by using the node tool. You select the 2 nodes where the gap is and use the connect node tool. To select the 2 nodes click on one then hold down the shift key and select the other. both nodes should be blue, then use the connect node tool to join the path.
Re: Hello
Thank you For such a fast response your information has taught me something new I opened up an operation and could change my start point that will at that point I produced a test plateOf random size holes on a square plate and ran the program it will not cut a complete hole it will shut the torch off just before the end of any cut but it is size proportionate what I mean by that is if you have a hole that’s a certain size it will shut off before the end of that hole just as any other hole that size and the outer plate will stop short of being complete 6x6 plate Torch shut off 1 inch before the end of movement I must’ve not checked some box somewhere it is to Precise I’m running a nvem control board
Re: Hello
Ok does the torch continue to move before raising up to go to the next start location. Are you saying that the larger the cut operation the farther from the end the torch quits and the torch continues to move to the end of the operation. One thing you can try is single stepping through the G-code without the torch on. Look to see if a M5 command comes before the end of the cut operation.
Re: Hello
Yes the torch Continues to move just as it should And I step-by-step through the G code and it looks right m5 is the last command before any z rise to next location and What I meant on the size of the portion uncut was just not random it had uniformity between holes And the torch is shut off at the end of every cut the same distance like 1.5 inch holes were the same as each other and the .75 holes were just alike always just not complete like C c
Re: Hello
N0010 (Filename: esd.tap)
N0020 (Post processor: Mach3 plasma THC with scriber and backlash compensation.scpost)
N0030 (Date: 22/05/2021)
N0040 G20 (Units: Inches)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: esd)
N0080 (Operation: No Offset, 3, T1: Plasma, 0.0591 in kerf)
N0090 G00 X6.7891 Y4.1852
N0100 G28.1 Z0.39 F19.685
N0110 G92 Z0.0
N0120 G00 Z0.0224
N0130 G92 Z0.0
N0140 G00 Z0.1181
N0150 M03
N0160 G04 P0.5
N0170 G01 Z0.0591 F6.0
N0180 F50.0
N0190 Y1.6852
N0200 (Operation: Inside Offset, 2, T1: Plasma, 0.0591 in kerf)
N0210 M05
N0220 G00 Z0.3937
N0230 X8.3800 Y4.5070
N0240 Z0.1181
N0250 G28.1 Z0.39 F19.685
N0260 G92 Z0.0
N0270 G00 Z0.0224
N0280 G92 Z0.0
N0290 G00 Z0.1181
N0300 M03
N0310 G04 P0.5
N0320 G01 Z0.0591 F6.0
N0330 X8.2833 Y4.4918 F50.0
N0340 X8.2256 Y4.4126
N0350 X8.2176 Y4.3795
N0360 X8.2109 Y4.3414
N0370 X8.2068 Y4.3029
N0380 X8.2052 Y4.2644
N0390 X8.2062 Y4.2258
N0400 X8.2097 Y4.1874
N0410 X8.2157 Y4.1494
N0420 X8.2242 Y4.1118
N0430 X8.2352 Y4.0748
N0440 X8.2485 Y4.0386
N0450 X8.2641 Y4.0033
N0460 X8.2820 Y3.9692
N0470 X8.3021 Y3.9363
N0480 X8.3243 Y3.9048
N0490 X8.3485 Y3.8747
N0500 X8.3746 Y3.8463
N0510 X8.4025 Y3.8197
N0520 X8.4321 Y3.7950
N0530 X8.4632 Y3.7722
N0540 X8.4958 Y3.7515
N0550 X8.5296 Y3.7330
N0560 X8.5645 Y3.7167
N0570 X8.6005 Y3.7028
N0580 X8.6373 Y3.6911
N0590 X8.6747 Y3.6820
N0600 X8.7126 Y3.6752
N0610 X8.7509 Y3.6710
N0620 X8.7895 Y3.6693
N0630 X8.8281 Y3.6702
N0640 X8.8668 Y3.6736
N0650 X8.9052 Y3.6796
N0660 X8.9432 Y3.6880
N0670 X8.9807 Y3.6989
N0680 X9.0174 Y3.7121
N0690 X9.0530 Y3.7277
N0700 X9.0876 Y3.7456
N0710 X9.1208 Y3.7658
N0720 X9.1526 Y3.7882
N0730 X9.1829 Y3.8126
N0740 X9.2114 Y3.8389
N0750 X9.2383 Y3.8671
N0760 X9.2632 Y3.8969
N0770 X9.2861 Y3.9283
N0780 X9.3068 Y3.9612
N0790 X9.3253 Y3.9953
N0800 X9.3415 Y4.0306
N0810 X9.3554 Y4.0670
N0820 X9.3670 Y4.1042
N0830 X9.3760 Y4.1421
N0840 X9.3826 Y4.1804
N0850 X9.3867 Y4.2191
N0860 X9.3882 Y4.2579
N0870 X9.3870 Y4.2968
N0880 X9.3834 Y4.3355
N0890 X9.3771 Y4.3739
N0900 X9.3684 Y4.4118
N0910 X9.3572 Y4.4492
N0920 X9.3437 Y4.4856
N0930 X9.3278 Y4.5211
N0940 X9.3096 Y4.5555
N0950 X9.2892 Y4.5885
N0960 X9.2667 Y4.6201
N0970 X9.2421 Y4.6502
N0980 X9.2155 Y4.6786
N0990 X9.1872 Y4.7052
N1000 X9.1572 Y4.7299
N1010 X9.1256 Y4.7526
N1020 X9.0925 Y4.7731
N1030 X9.0581 Y4.7913
N1040 X9.0225 Y4.8073
N1050 X8.9858 Y4.8209
N1060 X8.9484 Y4.8321
N1070 X8.9105 Y4.8409
N1080 X8.8721 Y4.8472
N1090 X8.8336 Y4.8510
N1100 X8.7970 Y4.8522
N1110 X8.7150 Y4.8386
N1120 X8.6542 Y4.8263
N1130 X8.6087 Y4.8147
N1140 X8.5706 Y4.8027
N1150 X8.5365 Y4.7896
N1160 X8.5036 Y4.7743
N1170 X8.4721 Y4.7564
N1180 X8.4412 Y4.7355
N1190 X8.4111 Y4.7117
N1200 X8.3826 Y4.6854
N1210 X8.3558 Y4.6570
N1220 X8.3309 Y4.6267
N1230 X8.3079 Y4.5947
N1240 X8.2871 Y4.5613
N1250 X8.2685 Y4.5267
N1260 X8.2522 Y4.4910
N1270 X8.2383 Y4.4545
N1280 X8.2267 Y4.4173
N1290 X8.2256 Y4.4126
N1300 X8.2176 Y4.3795
N1310 X8.2109 Y4.3414
N1320 X8.2068 Y4.3029
N1330 X8.2052 Y4.2644
N1340 M05
N1350 G00 Z0.3937
N1360 X7.2216 Y5.0646
N1370 Z0.1181
N1380 G28.1 Z0.39 F19.685
N1390 G92 Z0.0
N1400 G00 Z0.0224
N1410 G92 Z0.0
N1420 G00 Z0.1181
N1430 M03
N1440 G04 P0.5
N1450 G01 Z0.0591 F6.0
N1460 X7.1534 Y4.9943 F50.0
N1470 X7.1549 Y4.8963
N1480 X7.2233 Y4.7904
N1490 X7.3225 Y4.7124
N1500 X7.4417 Y4.6710
N1510 X7.5678 Y4.6705
N1520 X7.6873 Y4.7110
N1530 X7.7870 Y4.7882
N1540 X7.8563 Y4.8936
N1550 X7.8876 Y5.0158
N1560 X7.8774 Y5.1415
N1570 X7.8134 Y5.2747
N1580 X7.7030 Y5.3729
N1590 X7.5633 Y5.4210
N1600 X7.5624 Y5.4211
N1610 X7.5050 Y5.4306
N1620 X7.4434 Y5.4203
N1630 X7.4185 Y5.4153
N1640 X7.3255 Y5.3856
N1650 X7.2153 Y5.2969
N1660 X7.1448 Y5.1742
N1670 X7.1237 Y5.0343
N1680 X7.1549 Y4.8963
N1690 X7.2395 Y4.7736
N1700 M05
N1710 G00 Z0.3937
N1720 X5.9236 Y5.2563
N1730 Z0.1181
N1740 G28.1 Z0.39 F19.685
N1750 G92 Z0.0
N1760 G00 Z0.0224
N1770 G92 Z0.0
N1780 G00 Z0.1181
N1790 M03
N1800 G04 P0.5
N1810 G01 Z0.0591 F6.0
N1820 X5.8303 Y5.2264 F50.0
N1830 X5.7855 Y5.1393
N1840 X5.7945 Y5.0194
N1850 X5.8403 Y4.9082
N1860 X5.9183 Y4.8167
N1870 X6.0209 Y4.7540
N1880 X6.1379 Y4.7261
N1890 X6.2577 Y4.7359
N1900 X6.3686 Y4.7825
N1910 X6.4596 Y4.8611
N1920 X6.5217 Y4.9641
N1930 X6.5487 Y5.0813
N1940 X6.5381 Y5.2010
N1950 X6.4741 Y5.3342
N1960 X6.3637 Y5.4324
N1970 X6.2240 Y5.4805
N1980 X6.2231 Y5.4806
N1990 X6.1657 Y5.4901
N2000 X6.1046 Y5.4799
N2010 X6.0795 Y5.4749
N2020 X5.9864 Y5.4453
N2030 X5.8470 Y5.3179
N2040 X5.7855 Y5.1393
N2050 X5.8023 Y4.9912
N2060 M05
N2070 G00 Z0.3937
N2080 X4.5411 Y4.8589
N2090 Z0.1181
N2100 G28.1 Z0.39 F19.685
N2110 G92 Z0.0
N2120 G00 Z0.0224
N2130 G92 Z0.0
N2140 G00 Z0.1181
N2150 M03
N2160 G04 P0.5
N2170 G01 Z0.0591 F6.0
N2180 X4.5885 Y4.7732 F50.0
N2190 X4.6826 Y4.7461
N2200 X4.7953 Y4.7766
N2210 X4.8937 Y4.8393
N2220 X4.9688 Y4.9286
N2230 X5.0139 Y5.0362
N2240 X5.0248 Y5.1524
N2250 X5.0004 Y5.2665
N2260 X4.9431 Y5.3681
N2270 X4.8581 Y5.4480
N2280 X4.7530 Y5.4989
N2290 X4.6376 Y5.5160
N2300 X4.5629 Y5.5056
N2310 X4.4299 Y5.4539
N2320 X4.3258 Y5.3564
N2330 X4.2655 Y5.2270
N2340 X4.2540 Y5.1034
N2350 X4.2823 Y4.9825
N2360 X4.3475 Y4.8768
N2370 X4.4429 Y4.7973
N2380 X4.5586 Y4.7522
N2390 X4.6826 Y4.7461
N2400 X4.8247 Y4.7911
N2410 M05
N2420 G00 Z0.3937
N2430 X4.6001 Y3.0669
N2440 Z0.1181
N2450 G28.1 Z0.39 F19.685
N2460 G92 Z0.0
N2470 G00 Z0.0224
N2480 G92 Z0.0
N2490 G00 Z0.1181
N2500 M03
N2510 G04 P0.5
N2520 G01 Z0.0591 F6.0
N2530 X4.6766 Y3.0057 F50.0
N2540 X4.7740 Y3.0164
N2550 X4.8723 Y3.0939
N2560 X4.9404 Y3.1989
N2570 X4.9710 Y3.3203
N2580 X4.9607 Y3.4451
N2590 X4.8967 Y3.5783
N2600 X4.7863 Y3.6765
N2610 X4.6466 Y3.7245
N2620 X4.6458 Y3.7247
N2630 X4.5884 Y3.7341
N2640 X4.5272 Y3.7240
N2650 X4.5022 Y3.7189
N2660 X4.4090 Y3.6893
N2670 X4.3133 Y3.6167
N2680 X4.2447 Y3.5180
N2690 X4.2102 Y3.4028
N2700 X4.2131 Y3.2827
N2710 X4.2531 Y3.1693
N2720 X4.3263 Y3.0740
N2730 X4.4254 Y3.0060
N2740 X4.5407 Y2.9722
N2750 X4.6609 Y2.9758
N2760 X4.7740 Y3.0164
N2770 X4.8881 Y3.1123
N2780 M05
N2790 G00 Z0.3937
N2800 X4.8089 Y1.1990
N2810 Z0.1181
N2820 G28.1 Z0.39 F19.685
N2830 G92 Z0.0
N2840 G00 Z0.0224
N2850 G92 Z0.0
N2860 G00 Z0.1181
N2870 M03
N2880 G04 P0.5
N2890 G01 Z0.0591 F6.0
N2900 X4.8266 Y1.2953 F50.0
N2910 X4.7709 Y1.3760
N2920 X4.6169 Y1.4329
N2930 X4.6160 Y1.4330
N2940 X4.5586 Y1.4425
N2950 X4.4970 Y1.4322
N2960 X4.4720 Y1.4272
N2970 X4.3791 Y1.3975
N2980 X4.2880 Y1.3297
N2990 X4.2209 Y1.2381
N3000 X4.1836 Y1.1308
N3010 X4.1794 Y1.0173
N3020 X4.2087 Y0.9076
N3030 X4.2689 Y0.8113
N3040 X4.3547 Y0.7369
N3050 X4.4586 Y0.6910
N3060 X4.5714 Y0.6776
N3070 X4.6831 Y0.6978
N3080 X4.7840 Y0.7499
N3090 X4.8651 Y0.8294
N3100 X4.9194 Y0.9291
N3110 X4.9420 Y1.0404
N3120 X4.9310 Y1.1535
N3130 X4.8720 Y1.2798
N3140 X4.7709 Y1.3760
N3150 X4.6323 Y1.4305
N3160 M05
N3170 G00 Z0.3937
N3180 X6.2431 Y1.2643
N3190 Z0.1181
N3200 G28.1 Z0.39 F19.685
N3210 G92 Z0.0
N3220 G00 Z0.0224
N3230 G92 Z0.0
N3240 G00 Z0.1181
N3250 M03
N3260 G04 P0.5
N3270 G01 Z0.0591 F6.0
N3280 X6.2457 Y1.3622 F50.0
N3290 X6.1784 Y1.4333
N3300 X6.0752 Y1.4626
N3310 X6.0743 Y1.4628
N3320 X6.0169 Y1.4722
N3330 X5.9559 Y1.4621
N3340 X5.9307 Y1.4570
N3350 X5.8248 Y1.4211
N3360 X5.7312 Y1.3446
N3370 X5.6661 Y1.2429
N3380 X5.6359 Y1.1259
N3390 X5.6437 Y1.0053
N3400 X5.6885 Y0.8931
N3410 X5.7661 Y0.8004
N3420 X5.8687 Y0.7366
N3430 X5.9860 Y0.7078
N3440 X6.1065 Y0.7169
N3450 X6.2181 Y0.7631
N3460 X6.3099 Y0.8418
N3470 X6.3725 Y0.9451
N3480 X6.3999 Y1.0628
N3490 X6.3893 Y1.1832
N3500 X6.3125 Y1.3324
N3510 X6.1784 Y1.4333
N3520 X6.0752 Y1.4626
N3530 X6.0743 Y1.4628
N3540 X6.0334 Y1.4695
N3550 M05
N3560 G00 Z0.3937
N3570 X7.6070 Y1.2564
N3580 Z0.1181
N3590 G28.1 Z0.39 F19.685
N3600 G92 Z0.0
N3610 G00 Z0.0224
N3620 G92 Z0.0
N3630 G00 Z0.1181
N3640 M03
N3650 G04 P0.5
N3660 G01 Z0.0591 F6.0
N3670 X7.5847 Y1.3518 F50.0
N3680 X7.5015 Y1.4035
N3690 X7.4456 Y1.4127
N3700 X7.3698 Y1.3997
N3710 X7.3477 Y1.3949
N3720 X7.2584 Y1.3642
N3730 X7.1687 Y1.2944
N3740 X7.1035 Y1.2014
N3750 X7.0684 Y1.0933
N3760 X7.0665 Y0.9797
N3770 X7.0981 Y0.8705
N3780 X7.1603 Y0.7754
N3790 X7.2476 Y0.7027
N3800 X7.3525 Y0.6589
N3810 X7.4655 Y0.6477
N3820 X7.5769 Y0.6702
N3830 X7.6768 Y0.7244
N3840 X7.7564 Y0.8055
N3850 X7.8087 Y0.9064
N3860 X7.8291 Y1.0182
N3870 X7.8158 Y1.1310
N3880 X7.7507 Y1.2614
N3890 X7.6407 Y1.3570
N3900 X7.5026 Y1.4033
N3910 X7.5015 Y1.4035
N3920 X7.4456 Y1.4127
N3930 X7.3698 Y1.3997
N3940 X7.3548 Y1.3964
N3950 M05
N3960 G00 Z0.3937
N3970 X8.3983 Y2.3610
N3980 Z0.1181
N3990 G28.1 Z0.39 F19.685
N4000 G92 Z0.0
N4010 G00 Z0.0224
N4020 G92 Z0.0
N4030 G00 Z0.1181
N4040 M03
N4050 G04 P0.5
N4060 G01 Z0.0591 F6.0
N4070 X8.3023 Y2.3416 F50.0
N4080 X8.2481 Y2.2600
N4090 X8.2382 Y2.1109
N4100 X8.2660 Y1.9641
N4110 X8.3297 Y1.8290
N4120 X8.4253 Y1.7142
N4130 X8.5467 Y1.6270
N4140 X8.6860 Y1.5731
N4150 X8.8344 Y1.5559
N4160 X8.9824 Y1.5764
N4170 X9.1205 Y1.6334
N4180 X9.2398 Y1.7232
N4190 X9.3329 Y1.8401
N4200 X9.3936 Y1.9766
N4210 X9.4181 Y2.1240
N4220 X9.4049 Y2.2728
N4230 X9.3547 Y2.4136
N4240 X9.3545 Y2.4140
N4250 X9.2616 Y2.5495
N4260 X9.1328 Y2.6514
N4270 X8.9796 Y2.7108
N4280 X8.9234 Y2.7226
N4290 X8.8253 Y2.7390
N4300 X8.7628 Y2.7337
N4310 X8.5832 Y2.6842
N4320 X8.4278 Y2.5812
N4330 X8.3123 Y2.4349
N4340 X8.2481 Y2.2600
N4350 X8.2382 Y2.1107
N4360 (Operation: Outside Offset, Layer_1, T1: Plasma, 0.0591 in kerf)
N4370 M05
N4380 G00 Z0.3937
N4390 X3.7795 Y1.2246
N4400 Z0.1181
N4410 G28.1 Z0.39 F19.685
N4420 G92 Z0.0
N4430 G00 Z0.0224
N4440 G92 Z0.0
N4450 G00 Z0.1181
N4460 M03
N4470 G04 P0.5
N4480 G01 Z0.0591 F6.0
N4490 X3.8700 Y1.2621 F50.0
N4500 X3.9075 Y1.3526
N4510 Y5.9359
N4520 X3.9161 Y5.9568
N4530 X3.9370 Y5.9655
N4540 X10.0849
N4550 X10.1058 Y5.9568
N4560 X10.1145 Y5.9359
N4570 Y0.3937
N4580 X10.1058 Y0.3728
N4590 X10.0849 Y0.3642
N4600 X3.9370
N4610 X3.9161 Y0.3728
N4620 X3.9075 Y0.3937
N4630 Y1.3526
N4640 Y1.5026
N4650 M05
N4660 G00 Z0.3937
N4670 X0.0000 Y0.0000
N4680 M05 M30
N0050 F1
N0060 G53 G90 G40
N0070 (Part: esd)
N0110 G92 Z0.0
N0120 G00 Z0.0224
N0130 G92 Z0.0
N0140 G00 Z0.1181
N0150 M03
N0160 G04 P0.5
N0180 F50.0
N0190 Y1.6852
N0210 M05
N0220 G00 Z0.3937
N0240 Z0.1181
N0260 G92 Z0.0
N0270 G00 Z0.0224
N0280 G92 Z0.0
N0290 G00 Z0.1181
N0300 M03
N0310 G04 P0.5
N1340 M05
N1350 G00 Z0.3937
N1370 Z0.1181
N1390 G92 Z0.0
N1400 G00 Z0.0224
N1410 G92 Z0.0
N1420 G00 Z0.1181
N1430 M03
N1440 G04 P0.5
N1700 M05
N1710 G00 Z0.3937
N1730 Z0.1181
N1750 G92 Z0.0
N1760 G00 Z0.0224
N1770 G92 Z0.0
N1780 G00 Z0.1181
N1790 M03
N1800 G04 P0.5
N2060 M05
N2070 G00 Z0.3937
N2090 Z0.1181
N2110 G92 Z0.0
N2120 G00 Z0.0224
N2130 G92 Z0.0
N2140 G00 Z0.1181
N2150 M03
N2160 G04 P0.5
N2410 M05
N2420 G00 Z0.3937
N2440 Z0.1181
N2460 G92 Z0.0
N2470 G00 Z0.0224
N2480 G92 Z0.0
N2490 G00 Z0.1181
N2500 M03
N2510 G04 P0.5
N2780 M05
N2790 G00 Z0.3937
N2810 Z0.1181
N2830 G92 Z0.0
N2840 G00 Z0.0224
N2850 G92 Z0.0
N2860 G00 Z0.1181
N2870 M03
N2880 G04 P0.5
N3160 M05
N3170 G00 Z0.3937
N3190 Z0.1181
N3210 G92 Z0.0
N3220 G00 Z0.0224
N3230 G92 Z0.0
N3240 G00 Z0.1181
N3250 M03
N3260 G04 P0.5
N3550 M05
N3560 G00 Z0.3937
N3580 Z0.1181
N3600 G92 Z0.0
N3610 G00 Z0.0224
N3620 G92 Z0.0
N3630 G00 Z0.1181
N3640 M03
N3650 G04 P0.5
N3950 M05
N3960 G00 Z0.3937
N3980 Z0.1181
N4000 G92 Z0.0
N4010 G00 Z0.0224
N4020 G92 Z0.0
N4030 G00 Z0.1181
N4040 M03
N4050 G04 P0.5
N4370 M05
N4380 G00 Z0.3937
N4400 Z0.1181
N4420 G92 Z0.0
N4430 G00 Z0.0224
N4440 G92 Z0.0
N4450 G00 Z0.1181
N4460 M03
N4470 G04 P0.5
N4510 Y5.9359
N4540 X10.0849
N4570 Y0.3937
N4600 X3.9370
N4630 Y1.3526
N4640 Y1.5026
N4650 M05
N4660 G00 Z0.3937
N4680 M05 M30
Re: Hello
I don't see much out of the normal, is the post processor labeled backlash compensation because you have a floating head. I don't remember using that post processor when I used a floating head switch. another thing I find interesting is the z speed after the pierce being F6 as very slow, mine is F60. I am not saying that is your problem very slow. I would try a different post processor.
