fab-cut owner
fab-cut owner
in process buying Fab-cut cnc plasma table
Re: fab-cut owner
Tell us all about it.
Re: fab-cut owner
havent got machine yet waiting to get shipped . its a used unit
Re: fab-cut owner
Is this Fab-cut in Canada? I believe Renee Barnes is their main guy to talk to, I'm just curious because I'm also on the hunt for another table. From what I've researched and heard they seem to have quite a good system.
Re: fab-cut owner
Seems be a good bunch . I have spoken to Rene seems be good guy deal with. what type metal work r u into? I am new to this cnc plasma world just trying to add little extra to business.
Re: fab-cut owner
I'm into a little bit of everything, fixing and repairing, a little stainless work, my biggest gig is building screwpiles.
Re: fab-cut owner
What is a "screwpile"?
Re: fab-cut owner
Welcome plasmalady! Hope you are able to get the machine and that it works out well.
I also wondered what a screwpile was David.
Re: fab-cut owner
Thanks plasmanewbie.plasmanewbie wrote: ↑Mon Jan 30, 2023 9:11 am Welcome plasmalady! Hope you are able to get the machine and that it works out well.
Re: fab-cut owner
not much good for Newfoundland mostly rock
Re: fab-cut owner
Wow, those are much larger than I had imagined. Very cool.
Re: fab-cut owner
Thanks Plasmanewbie! I guess I was too lazy to let Google be my friend. But that explains it quite well.plasmanewbie wrote: ↑Mon Jan 30, 2023 9:11 am Welcome plasmalady! Hope you are able to get the machine and that it works out well.
Re: fab-cut owner
Jason - thanks for those photos! Very impressive work. What sort of big machine is required to install these? And is this something you do as well, or are these for customers?
Re: fab-cut owner
We install these as well... we also build some for customers. here's a link that will explain the process better than I can, thanks for the compliment.
https://innovativepiling.ca/about/
Re: fab-cut owner
what is used the most cold rolled steel or hot rolled steel in sheets for cnc plasma cutting
Re: fab-cut owner
Good question: Cold rolled does not have the thin slag coating while hot rolled requires more prep is some situations prior to paint or staining etc where as cold rolled has been coated with oils so you get dirtier handling it and it will rust faster out in the elements where as Hot Rolled can sit in the rain and weather with less rust/surface deteriation. I believe cold rolled is more expensive. Think it mostly boils down to what kind of finish the end result required. Anything I am missing here guys?plasmalady wrote: ↑Sun Feb 05, 2023 7:26 pm what is used the most cold rolled steel or hot rolled steel in sheets for cnc plasma cutting
Re: fab-cut owner
I would say it's probably 50/50 or so. Many use hot rolled to save some money. My local supplier usually has them priced about the same, and sometimes cr is actually less expensive than hr. I suppose it just depends on your suppliers.plasmalady wrote: ↑Sun Feb 05, 2023 7:26 pm what is used the most cold rolled steel or hot rolled steel in sheets for cnc plasma cutting
Re: fab-cut owner
i own fab cut table they are awsome after sale service is a1 table run great ive purchased it in 2022
Re: fab-cut owner
That is good to know, thanks for the info. I'm dealing on a used unit right now...lavoiemaxi wrote: ↑Mon Feb 13, 2023 8:40 pm i own fab cut table they are awsome after sale service is a1 table run great ive purchased it in 2022
