CNC Compatible Plasma Cutter
jeremy_smitty
Post by jeremy_smitty »
WIll this unit work on a CNC plasma table?
I am not looking for responses on whether or not I should get a plasma from Amazon...just whether this unit will work on a CNC plasma table.
If not, what are the requirements for a machine to be compatible?
Re: CNC Compatible Plasma Cutter
I don’t see any reason why it would not work for you. The important thing is a non hf start which it has so you should be good to go.
andrewbwerdna
Post by andrewbwerdna »
do you know if that yeswelder is 1:1 voltage divider, 20:1 or 50:1
jeremy_smitty wrote: Sun Nov 19, 2023 4:58 pm WIll this unit work on a CNC plasma table?
https://www.amazon.ca/YESWELDER-CUT-65D ... r=8-3&th=1
andrewbwerdna wrote: Thu Feb 13, 2025 8:35 pm do you know if that yeswelder is 1:1 voltage divider, 20:1 or 50:1
Andrew - the Amazon listing makes no mention of a built in voltage divider. So you will need to add one externally for use with your cnc controller.
I agree with David, it will likely have no voltage divider so the only arc voltage signal available to you will be 1:1.
andrewbwerdna
Thanks, i got a proma, it looks like they accommodate all scenarios. Just wanted to correct connect.
