Rattle Can Paint Shaker
goldwinger
Post by goldwinger »
Has anyone seen or know of a DIY shaker that can shake several (up to 6) rattle cans at the same time ?
I have tried several DIY attempts at making something but not muck luck, open to any thoughts you might have
GoldWinger
Arc Pro 4800
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
rons
Re: Rattle Can Paint Shaker
Post by rons »
I want one too
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
yroc fab
Post by yroc fab »
If im needing to shake 6 spray paint cans im getting out the paint gun.
urbnsr
Post by urbnsr »
You could start with Harbor Freight's 1 gallon paint shaker:
https://www.harborfreight.com/pneumatic ... 94605.html
You can shake up to three rattle cans as is. I would look into adding a jig to hold six cans, if needed.
HTH
Paul
harrymorley
Post by harrymorley »
I have never tried putting a rattle can in a paint shaker. It is my understanding the can can't stand the vigorous shaking action and they rupture. NOT OSHA RECOMMENDED. Maybe if the motion were slowed considerably it would be safe. Myself, I wouldn't even attempt it.
lockeyone
Post by lockeyone »
I think since the Harbor Freight one runs on air you can easily slow it down to a reasonable shaking motion.
Epilog Mini 24 60watt, 2013
motoguy
Post by motoguy »
abmetal
Post by abmetal »
I bought the HF shaker years ago just for rattle cans and I've never had a problem. Common sense wins over OSHA in this case.
Allen
99guy
Post by 99guy »
abmetal wrote:I bought the HF shaker years ago just for rattle cans and I've never had a problem. Common sense wins over OSHA in this case.
Allen
ditto
TruCutCNC Series1 Gen2 4x8 water
TruTrac THC
Powermax 85 . M85 Torch
TD A120 . SL100SV1
Mach 3 . SheetCam . CorelX6
Post by tnbndr »
Here's a tool for one.
Anyone else on here use this?
I bought one a year ago, couldn't find it so bought another. First one broke at the tang where it enters the sawzall after about 20 cans. Second one broke same place after only 4 cans. Contacted the owner and he claims no one else has this problem.
Always just me!!!!
Rex
Post by Rex »
HF shaker has work for me for years with no problems
Many cans a week
I did see the price went way up
Hypertherm 65
ddfarmboy
Post by ddfarmboy »
I know this isn't a shaker, but it has been working for me for several years... I have an old "rock tumbler" designed for 2 drums and it is just the perfect length for a can of spray paint or quart cans of paint. I start to tumble paint as I am prepping for paint... give each cam 5-10 minutes initially if I need multiple cans. End with the can I start spraying with and put another one on a second time. By the time I use up one can the next is ready. Definitely noticed fewer plugged nozzles versus just hand shaking.
james.davis
Post by james.davis »
I bought this a couple years ago only holds one can but man works like a charm.
Jim
looks neat and they still sell them on eBay
