Air Compressor Oil Weight for cold weather?
john527
Post by john527 »
My compressor is in a unheated pole barn in Michigan, I noticed it starts up somewhat slow when cold, should I put a lighter weight oil in it like maybe 20 wt? just wondering if anybody else has this problem?
Re: Air Compressor Oil Weight for cold weather?
If your running a straight 30w try going to a 5w30 synthetic motor oil. I just use Mobil 1 synthetic and compressor starts easy in the cold. My shop would be a little warmer than a pole barn but this should help.
Desertdog
Post by Desertdog »
I use one of these Wolverine heaters with a thermal cube. They make different sizes and wattages for your application/location.
https://www.wolverineheater.com/collect ... 5118636434
https://www.wolverineheater.com/collect ... 5118737810
Westcott Retro 5x10
Design2Cut software, CAD, CAM, CUT, all in one program.
Hypertherm 45XP
Champion 2 stage compressor, 7.5 HP motor, 15 HP pump (QUIET!),
80 gallon tank, auto tank drain, mag starter, after cooler.
25.8 CFM@175
BAR M
Post by BAR M »
It doesn't get too cold here in central NM, but I have a cheap and simple "Auto Zone" engine block heater mounted right on the crank case.
john527
Post by john527 »
I also found that my belt was lose...what a difference that makes!
tylerd
Post by tylerd »
Desertdog wrote: Mon Dec 03, 2018 12:59 pm I use one of these Wolverine heaters with a thermal cube. They make different sizes and wattages for your application/location.
I know this is an old post, but I am looking at this same compressor, how has it worked for you? Is this the reed or disc valve version? Have you had any problems with it?
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
