IGBT needed
IGBT needed
anyone used an aftermarket IGBT to replace 16X1721 thermal dynamics cutmaster 50, appears to be obsolete
Re: IGBT needed
The trick is to find an IGBT with the same or better volts and amp specs and the same mounting "footprint " It gets trickier if the signal cables for the trigger are in one connector so the lug pattern has to match. I had to do it on a Pick and Place machine about a year ago. Figuring out the control wires was the hardest part. If you can get a spec sheet on the one that is in there it will go a long ways in finding a replacement. If there are two replace them both.
