Steel size
Buresh
Steel size
Post by Buresh »
I am having problems with my steel warping I am using 16 gauge trying to do decorative artwork what size is everybody else using for steel
DezertBlingMoto
Re: Steel size
Post by DezertBlingMoto »
you can use 16ga. you just have to play with your ipm and heat/voltage/cutting height . Hope that helps a bit , im sure someone will shimmy in some more intel .
Buresh
Re: Steel size
Post by Buresh »
What is the recommended ipm? Im using a lotos ltp 5000d cutter brand new to this.
Stocker3779
Re: Steel size
Post by Stocker3779 »
I use a Powermax45 at 100IPM and 33 amps for 16ga. Run test patterns on some scrap to get it dialed in.
Buresh
Re: Steel size
Post by Buresh »
Thank you i will try that
Thor
Re: Steel size
Post by Thor »
I use a Powermax 85 with finecut tips running 45amps at 250-300 ipm. How fast you can go depends on your machine and how well it handles corners etc, then its just a matter of getting the amps and voltage set for that speed. (basically, there are other variables too, I get pretty much slag free cuts with my settings)
16ga is the thickest I cut with finecut tips.
SegoMan DeSigns
Re: Steel size
Post by SegoMan DeSigns »
PM 65 / 45Amps / fines / 120 ipm on 16 ga. with water table.
Thor,
The fine cuts will do 11 ga with no probs.
ctgolfer1
Re: Steel size
Post by ctgolfer1 »
When I am cutting 16 ga or thinner I make sure the water table is full, I make sure I don't cut much in one area, make sure to split up the design and I use 30 amp tips @27 amps.
I set the cut speed to 180 ipm and use a 90 degree lead in.
Very little dross, mainly on the corners that can be squeezed off with my fingers.
Almost no warping at all.
This was last week, fine detail,
Good luck man.
Thor
Re: Steel size
Post by Thor »
SegoMan DeSigns wrote: Tue Sep 10, 2019 11:54 am Thor,
I have done up to 12ga with the fine cut tips but typically I am doing production parts and am more concerned with speed (secondary is quality, then tip life). So I usually start going to 65 amp tips at 50 to 65 amps depending on thickness. Doing artwork with lots of detail I may occasionally use finecuts up to 12ga.
SegoMan DeSigns
Re: Steel size
Thor wrote: Tue Sep 10, 2019 4:18 pm
My 11 ga projects were sliding brackets and tabs for the sliding brackets, CNC kicks but on ob-longed holes :Wow
