Hi,
I'm new to this field and I need some information as I'm building a THC controller for a plasma with contact ignition. Can you tell me what the maximum voltage and frequency are? Also, does anyone have any voltage peak readings on an oscilloscope that I could use to observe the waveform and ripples?
request for information about building a THC controller
Re: request for information about building a THC controller
Welcome aboard! You might consider asking your question in the DIY section of the forum for better responses.
viewforum.php?f=103
viewforum.php?f=103
Hi, okay, I'm posting the question in that section.
Good luck with your questions, and I hope you find the information you seek.
http://linuxcnc.org/docs/devel/html/pla ... e_sampling
https://www.google.com/url?sa=t&source= ... Z48rCjiocH
good luck.... but if I were you... I'd just learn linuxcnc and buy a thcad as all the hard work has been done.
http://store.mesanet.com/index.php?rout ... uct_id=128
http://linuxcnc.org/docs/devel/html/pla ... asmac.html
