Angle Plasma Cut
tassleholf98
Angle Plasma Cut
Post by tassleholf98 »
Hi guys
LDSCNC 5x10
Hypertherm powermax 105
sheetcam and mach 3
Newb here, running a test on 3/8 ar500 steel, I have not been running anything thicker than an 1/8,
Angle of the cut is :Wow
How do i fix this please .
SegoMan DeSigns
Re: Angle
Post by SegoMan DeSigns »
Re: Angle
Hard to tell from the picture for certain but it looks like you may be cutting with your torch too high from the material.
What amperage were you using to cut that?
If your cutting at 85 amps the proper torch to work distance will be different than if you chose to cut it at 105 amps. Determining from the cut charts the proper height and actually pausing the machine mid cut to measure it (rather than just trusting your machine has the torch at the correct height) is important.
I like to do straight line cuts to get my height tweaked just perfect before cutting production parts.
Pics of all 4 sides of the part will also help us to determine what the cause may be.
This is a great topic on torch height and cut angle which may help https://www.plasmaspider.com/viewtopic. ... 02&t=30283
tassleholf98
Re: Angle Plasma Cut
Well don't i feel a complete dumbass...
I had a fine cut 45A tip in the damn thing ..
Sorry for wasting ya time guys ......
I am sure there will be some more dumbass mistakes by yours truly..
Sounds like you found the problem, thanks for passing that along. Always help to have a solution, it may help others in the future.
Be sure many of us known it easy to make a simple mistake. :HaHa :HaHa
Ah right on, that could do it, glad you found a simple fix. Are your cuts looking much better now?
tassleholf98
weldguy wrote: Thu Jul 13, 2023 10:18 am Ah right on, that could do it, glad you found a simple fix. Are your cuts looking much better now?
Cuts are much better now , i still feel a little stupid
tassleholf98 wrote: Thu Jul 13, 2023 2:09 pm Cuts are much better now , i still feel a little stupid
Understandable but I think everyone on here has done something similar or worse at some point. Lot of variables to get things working right and it's tough to remember them all, particularly if your new to the game.
ROKCRLER
Post by ROKCRLER »
I forget to turn on the compressor sometimes and chase my tail looking for why my cuts are crap or i lose flame or whatever...
4x8 Dynatorch
PM85
~Mo~
