Need help can’t figure it out!!
With lead in I get a cut that doesn’t meet up at the end and leaves a notch. With no lead in I get the same but much cleaner. I’ve messed with almost every setting and I’m getting no results. New consumables using a Hypertherm 45xp premier plasma table Mach 3 and sheet cam software
Re: Need help can’t figure it out!!
post your gcode please (both)
have you got thc? how are you turning it on and off
It has the thc and what do you meaning turning it on and off?
can you post your gcode files to have a look at please.
how do you turn your THC on and off (simple question).... do you use an Mcode? is it stand alone?
is the THC being turned on and off for that cut?
mach3 only has one function to control outputs in sync with motion M11+M10
