Hello,
I saw the Autodesk AutoCAD forum but didn't want to post there and break any rules.
While working on a fireplace log storage door I ran into this problem.
If anyone can point me in the direction as to why it's doing this I'd be greatly appreciative.
As you can see when i select the material i want to keep and extrude it sees it all just fine then i tell it to actually extrude it and it has these areas where its not cutting.
Thank in advance for any help.
Using fusion 360 strange extrusion
Re: Using fusion 360 strange extrusion
Seems i step away from this software for just a day and I forget what I'm doing when i get back.
I figured it out. Turns out there was a discrepancy along the timeline in the lower left. It had two of the blocks greyed out. I selected the timeline and selected to delete everything past the marker.
It's done this before I just had a brain fart and forgot.
From 1:13 to 1:43 did not take you long, brain fart of not you feel better when you figure it out yourself, less likely to do it again.
lol true. Getting up there in years is not what I had planned.
I know the feeling any new things go into my right ear and old things fall out the left ear.
