Hi! Our file won't save because it says there is an invalid cut path. It was totally fine and then we edited a corner of the design and now it gives that warning whenever we try to save. That corner of the design came up as an open line suddenly as well.
Any ideas? We've already tried smoothing, set it to delete overlapping segments, exploded and checked for extra lines, etc. Nothing works Any advice would be greatly appreciated.
We have a DHC machine (old software) but it doesn't usually give us much trouble.
Invalid cut path help needed
Re: Invalid cut path help needed
Best to attach the file here so we can look at it. Chances are if you zoom in close enough you will see the break in the line or a line on top of another line, something like that.
I wish I could. The problem with the file won't let me save it, though So no dice on that. I'm looking for a line on top of another line probably though? We did find one lone pixel floating alone and hoped that was it, but it wasn't the problem apparently.
- Joe Jones
You do not edit cut paths. If you are not happy with the design is it going to cut, you DELETE the cut paths, and edit the open and closed paths until the file is correct. Then you convert the adjusted file consisting of open and closed paths to cut paths.
Post the original file if you can, and tell us what change(s) you wanted to make. I can make the changes and check the file for errors, and then upload the corrected file.
- rdj357
On 3.11 or older, when you convert to cut path it replaces the open and closed paths so this is not likely an option for them. I still agree that you should not be editing cut paths and would recommend that with the older software, you save a copy of the design first and then convert it but be careful to never save over the top of your unconverted designs.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
