When things go wrong... How to fix?
Tristar500
Post by Tristar500 »
Hey Guys,
I've been using Mach 3 for about 20 years but still far from being an expert and most of my experience has been with Mill, laser and router.
When something rotten happens during an operation I can usually just re-home and start again. (after obligatory swearing and changing broken cutters etc.)
Since plasma cutters don't take kindly to re-cutting a partially finished job (torch following previous cut, which is now just a gap of air)
What kind of strategies have you come up with to pick up where things went wrong?
Yesterday while getting some bugs out of a new plasma build I had a torch "no start". Mach 3 stops looking for arc ok.
I solved the issue by inspecting the torch and servicing the consumables and re-opening the cad program to delete the cuts already finished.
Anybody got any hints and tips on this?
Thanks all!
This forum is a lifesaver!, Glad I joined as a contributing member. :Yay
50X50 plasma w/ pneumatic drill- own design
Mach3,4 SheetCam, CorelDRAW 2020
Homebuilt 3 axis mill
Homebuilt 5 axis mill
PrimeWeld cut 60 Plasma
Hypertherm 350
Miller Symchrowave 250 DX
Several mig welders
He who is without oil shall throw the first rod
Compressions 8.7:1
ROKCRLER
Re: When things go wrong... How to fix?
Post by ROKCRLER »
I keep a scrap piece of 16ga handy and place on the spot it stopped or over the part already cut to continue.
4x8 Dynatorch
PM85
~Mo~
Post by djreiswig »
Back up to the previous m05. Disable THC and step until the m03 line. Skip that line and start code from the next line. Watch the torch and right before it hits the uncut material, fire the torch & turn THC on.
34by151
Post by 34by151 »
Have fixed up a lot of mach3 plasma cutters.
I always add a "save origin" and "restore origin" button to the GUI
Its easy to loose position with Mach3 and if you do it's a nightmare
Another tip is to have Mach3 in absolute (not relative) mode
Allways Home before staring a job
Jog to your start position and save the origin
Mach3 will make your start position 0,0
Home, restore origin
You can then move to M03 where the last cut was and restart
This is where having your PP generate absolute moves comes in handy
If you have it set for relative moves you would need to do all the moves from the origin to the cut you want
This means deleting all the M3/M5's before the cut you want
Joe Jones
Post by Joe Jones »
On those occasions where the torch stops for any of a hundred different reasons, I start the cutting process again and turn off the torch. The machine goes through the motions and when it approaches the point where the torch stopped cutting, I turn the torch on and it picks up from there. The PlasmaCam table controller has a button that turns the torch on and off.
Dingo74536
Post by Dingo74536 »
I have not used it myself yet and it is not Mach3 related but one of the features of the Proma Myplasm system is the Resume Function that is built into the control software which theoretically can save your bacon when it goes wrong. I have pasted the text from the manual less pics obviously but it might give you the idea of how it works.
Resuming cutting.
Depending on the circumstances of the interruption, the work can be
resumed in several ways. In the case of a simple stop with the STOP
[ ESC ] BETWEEN TRACKS key ( recommended ), simply click
START [ F5 ] and the system will automatically resume from next path.
When you have stopped working UNDER CUTTING a track, the
START [ F5 ] button will start cutting it from the beginning. In order to
start from the stopping point, click START with the Right Mouse Button
or the [ F6 ] key.
It is possible to start cutting from ANY POINT by simply pointing to
it with the right mouse button and selecting " Start track from this point "
from the menu.
If a track is not cut enough, it is possible to start cutting it in the
opposite direction which will allow it to be cut "from the end". To do this,
select the one of tracks and click START with the CTRL key held down.
Tristar500
Joe Jones wrote: Sat Jun 10, 2023 11:17 am On those occasions where the torch stops for any of a hundred different reasons, I start the cutting process again and turn off the torch. The machine goes through the motions and when it approaches the point where the torch stopped cutting, I turn the torch on and it picks up from there. The PlasmaCam table controller has a button that turns the torch on and off.
That seems to be working for me although It can be tedious when the torch fails near the end or a large job. The program comes to a stop when it doesn't get an "arc ok" signal and I have to hit the torch off button at the start of every cut to make it move on to the next.
I'm still working on getting the hang of the "run from here" feature in Mach 3.
Hypertherm 350
Several mig welders
Compressions 8.7:1
Post by djreiswig »
Move to the m05 right before the failed spot and hit set next line. Then single step to the m03. Skip ahead 1 line and hit set next line again. Then start and manually fire the torch when it gets to the uncut area.
Tristar500
djreiswig wrote: Sun Jun 11, 2023 5:25 pm Move to the m05 right before the failed spot and hit set next line. Then single step to the m03. Skip ahead 1 line and hit set next line again. Then start and manually fire the torch when it gets to the uncut area.
I'm a little weak on the set next line and start from here.
Hypertherm 350
Several mig welders
Compressions 8.7:1
Post by djreiswig »
Never used start from here. I don't think I even have that button. I back up to the m05 so that I get the reference and the correct x y moves to get the torch where it needs to be.
Return to “Mach3 & Mach4 CNC”
