Mach4 torch will not fire no THC
Codeblu06
Post by Codeblu06 »
First off I just want to thank everyone on these forums. I have found the answers to many, many questions by just finding the answers here. This time however I cannot find an answer.
Here is what I have for a system. It is home built.
G540
Sheetcam- using generic Mach4 Post Processor.
Mach4
No THC the table is 4' x 4' I haven't needed one so far.
ESS Warp9td
No probe
Here is what's going on. I have been using Mach3 with little problems. I thought I would change to Mach4 because I have problems with CV. I have spent the last three days setting everything up and testing, but the torch will not fire. After I hit cycle start it will run the g code till it gets to the M3 code:
N0010 (Filename: SJ test 14 GA Fine M4.tap)
N0020 (Post processor: Mach4 plasma.scpost)
N0030 (Date: 19/11/2021)
N0040 G21 (Units: Metric)
N0050 G90 G80 G40
N0060 (Part: SJ test)
N0070 (Operation: Outside Offset, Layer_1, T11: 14ga FineCut Mild Steel)
N0080 (14ga FineCut Mild Steel)
N0090 G00 Z38.1000
N0100 X-5.4378 Y2.7754
N0110 Z3.8100
N0120 M03
ect................
It stops there. I look at the history and this is what it says:
ESS starting Probe 0
!!!!! ESS: Probe hardware not setup. Digitize signal not mapped! Probe# 0
Can't transition from PROBING to RUNNING
MACRO ALARM: 3 MERROR_NOT_NOW
ESS: Mach4 Enabled
Do Cycle Start
Can someone please help! I am lost at this point.
Thanks in advanced!!
Re: Mach4 torch will not fire no THC
It has been a long time since I looked at Mach 4, but with Mach 3 there is a probe pin under the input pins. You may have accidentally enabled the probe input in Mach 4 and it is looking for it. Or the post processor is setup to use a probe. The normal probe command in G-code is g31, but I don't see that in the g-code you supplied.
Codeblu06
Post by Codeblu06 »
I Just checked the Input pins. The only one I had selected were the EStop, Torch Up, Torch Down, and Torch Arc Ok. I just went in and deselected the torch up down and Arc no difference. It still stops at the M03 code. I also looked through all the code and there was not a G31 even after what I pasted above. I don't know anything about post processors but can I edit the Mach3 post to fit my needs. I tried using that post but it wants me to make a tool change at M06 line.
djreiswig
Post by djreiswig »
Look at your M3 macro. It appears that it is what is throwing the error. Maybe the probing routine is in the macro.
djreiswig
Post by djreiswig »
https://warp9td.com/index.php/gettingst ... EssProbing
It looks like you're supposed to configure mach 4 through the ess plugin config, and it fills in the Mach settings.
Codeblu06
Post by Codeblu06 »
djreiswig wrote: Sat Nov 20, 2021 5:31 pm Look at your M3 macro. It appears that it is what is throwing the error. Maybe the probing routine is in the macro.
Forgive me for not knowing, but how can I do that.
djreiswig wrote: Sat Nov 20, 2021 5:38 pm https://warp9td.com/index.php/gettingst ... EssProbing
I have set those parameters through Ess Config but there is not a selection to not have a probe.
djreiswig
Post by djreiswig »
I use mach 3, so I'm not sure where mach 4 stores it's macros. In mach 3 there is a folder in the Mach folder with your profile name. In that folder is a macros folder that has all of the macros for that profile. You can edit them in notepad. See if there is a g31 in the M3 macro.
Codeblu06
Post by Codeblu06 »
Ok. Thanks. Here is what is in the m3.mcs:
function m3()
mcTHC.FireOn()
end
if (mc.mcInEditor() == 1) then
m3()
end
I have looked at the other macros in the folder and none of them have a G31.
Return to “Mach3 & Mach4 CNC”
